Thread: Help connecting receiver to sub |
New member Username: Jzh11
Post Number: 1 Registered: Jul-09
| Posted on Sunday, July 05, 2009 - 08:08 pm: |
The first thing I did for my home audio was run speaker wire through the attic. Come to find out my receiver does not have a speaker wire out for the sub. Is there a way to connect RCA's to speaker wire. Another possible problem is the receiver only has 1 out for the sub, I'm assuming this must be the left side? But the sub has input's for R and L. Will this be a problem? Thanks for any help |
Platinum Member Username: Nuck
Post Number: 12872 Registered: Dec-04
| Posted on Sunday, July 05, 2009 - 09:04 pm: |
JH, your sub may accept high(speaker level) input, in which case you are fine. A 'Y' splitter is usually employed to take your LFE output from a single end at the receiver to the stereo input on the sub. Hope this helps. |
Post Number: 2 Registered: Jul-09
| Posted on Sunday, July 05, 2009 - 09:23 pm: |
Nuck, I understand what your saying, and that may be my only choice. What I want to avoid is getting back into my attic (in florida). I already have all the speaker wire run and would like to utilize this if possible. |
Post Number: 12877 Registered: Dec-04
| Posted on Sunday, July 05, 2009 - 09:27 pm: |
If your sub has speaker level inputs, then you just connect them to your regular speaker terminals, 2 wires per connection. Coward, put in a bathroom vent while you are up there. |
Post Number: 3 Registered: Jul-09
| Posted on Sunday, July 05, 2009 - 09:34 pm: |
Haha, the less time I spend in that attic, the better. So your saying I dont have to use the designated sub output on the receiver. Just the regular speaker outputs will work? |
Post Number: 12878 Registered: Dec-04
| Posted on Sunday, July 05, 2009 - 09:36 pm: |
If your sub accepts speaker level inputs, yes. What is the sub? Or is this where the details come in? |
Post Number: 12879 Registered: Dec-04
| Posted on Sunday, July 05, 2009 - 09:39 pm: |
I am gonna be in FLA week after next, and while that helps neither your sub-connection, nor your present ventilation of the facilities, I can imagine that the attic is not a great space for a campout. |
Post Number: 4 Registered: Jul-09
| Posted on Sunday, July 05, 2009 - 09:57 pm: |
It definitly is not. The sub is a Polk Audio. Model # RM6750. It came in a Polk Audio 5.1 speaker set up. The receiver is a Yamaha RX-V565 |
