Home > Message Board > Home Audio > Speakers > Archive through August 16, 2009 > Need B&W 685 opinions
Author Thread: Need B&W 685 opinions
Username: James_the_god
Lancaster, Lancashire
England
Post Number: 758
I'm thinking of upgrading my speakers to the Bowers & Wilkins 685 because I want a bigger and more musical sound over my AE neo 1s.
I would go with a floorstander if the space allowed and after much consideration, I think the 685 would be my best bet!
I feel like my current speakers are slightly boring a lot of the time, they're good and even look fab but I'm after more.
Opinions on the 685 please, as I'd have to save up for these! Note that I have heard them in store and I liked them, but the bass was a little bloated. I think this was their store and setup since they had just had them a week.
I'll be sticking with my A&R A60 amp.
Thanks
JJ
Username: Nuck
Post Number: 12769
The 685's will sound bloated anywhere, placement is meant to be in mid-room, no corners or walls.
Don't think so JJ.
Keep looking.
Think bookshelves or standmounts with front ports, maybe the Focals?
England
Post Number: 759
I was hoping that wouldn't be said but I'm glad thats the truth of the matter Nuck!
I have considered the 706vs, I liked the highs on the 705s when I demo'd them, especially with string instruments, but going back to the neo 1s proved how much more detail, balance and bass impact they have.
If only AE did a standmount with a slightly bigger main driver and cabinet!!
Username: Nuck
Post Number: 12771
Adjust to a life of tradeoffs, JJ.
Thats just my take on the 685's but I think it is a shared opinion.
Ever heard Audio Note?
The AN-E is MEANT to be in a corner or against a wall. Sonically diverse.
England
Post Number: 760
I should adjust more shouldnt i!
Never heard of audio note, the AN-E looks interesting though, and HUGE!
I'll also give the others a look too, I bet they're all expensive!
Just found this website.
http://www.bigearsaudio.org.uk/index.html
Looking at the stuff on here..WOW! In the second hand speaker list, the Nuforces look very nice! Twin driver much like the aelite 2s I was considering and am I again since they have a pair on there for a good price!
Username: Nuck
Post Number: 12775
The AN-E(england) and AN-j(Japan) are both fairly well regarded, with the E model winning the day.
If you are thinking short term and $, JJ then look elsewhere, but the AN are well regarded and pretty flexible, you could go through a bunch of mid-fi stuff and end up with a good pair of speakers 5 tries from now.
Don't pawnshop your tux for them, but consider...
England
Post Number: 761
I'm intrigued to hear the Audio Notes now.
What about the AN-X? That dealer does the AN-X 2? Or is this a little mid-fi too?
England
Post Number: 762
Ignore that, I dont think they do that anymore!
Username: Kbear
Post Number: 145
The 685 are on my list as a possibility if I opt for new speakers. I heard them and I enjoyed them, I guess what I've found through listening to many speakers is that I do enjoy that strong bass presence.
What about the NHT Classic 3? On sale everywhere right now. Bass is probably similar to the 685 though.
If you want a quicker, less bloated sound, then check out the new Tannoy Revolution series. I haven't heard them personally, but this is the impression I get from those who have. Not cheap though, retails for 600 pounds.
http://www.techradar.com/reviews/audio-visual/hi-fi-and-audio/hi-fi-and-av-speak ers/tannoy-revolution-signature-dc6-356922/review
A lot of people here seem to like the Totem Rainmaker too and sounds like it would have what you are after.
How about the new Rega RS1?
http://www.techradar.com/reviews/audio-visual/hi-fi-and-audio/hi-fi-and-av-speak ers/rega-rs1-96496/review
Personally, if I opt for new speakers I will be listening to all of the above. They all seem like good options in the $600-$1,200 price range.
Username: Nuck
Post Number: 12783
Tannoy know how to make good quality, high efficiency speakers, but I have questions about the finish(if that matters).
Very good speakers, spotty dealers and support in Canada, as much as I have seen.
Username: Frank_abela
Berkshire
UK
Post Number: 3672
My views:
I think the 685 (£389?) is possibly B&W's best speaker in that range. I quite like it (saying something), but it is big in the bass so if space is at a premium I would probably discount it as an idea. I also note you're using an A&R A60. The B&W is hard to drive so this is really not a very good idea in my view.
Focal 706V (£379?) - easier to drive, more sensible in the bass and very very articulate in the midrange. Good speaker. That said, the A60 might struggle a bit.
AE neo-1 (£not sure?) - not too different than the above in fidelity terms I think. Yes, the AE may have a bit betetr resolution than the others thanks to the ring radiator tweeter. Yes, the B&W's bass will impress a bit and yes the Focal's midrange will impress, but overall we're talking differences rather than improvements methinks.
Things to consider:
You mention wishing for a floorstander. Consider the Rega RS-3 (£684) or standmount RS-1 (£400). I was playing with the RS-3 on Saturday and I think it's a major improvement over the R-3. Very engaging, very easy to drive and more efficient than average so a snap to match your A60. Front ported so they can work closer to the wall than other speakers. This could be the answer, but a bit more expensive than the 685/706V (not too much more when you include stand price).
Totem Dreamcatcher (£525). Tiny speaker but lots of fun with a big sound, even after considering the size.
Naim n-Sat - an unsual choice from an unusual source. More expensive, designed to go against the wall. Some people complain that Naim speakers don't do bass, but I disagree and everybody who's heard them agrees that what's there is articulate and fast. The rest is like a wide open window by comparison to your current leaded glass. But they're not cheap at £785.
All that said, I think you may be looking in the wrong place...
All this rather depends on what electronics you're using. The A60 is out of the ark so should you be considering replacing a relatively new speaker when you're using such an old class A amplifier which is likely to be pretty shot already? (Class A operation is pretty hard on components.)
Furthermore what about your source? If it's CD, then is it a good CD player or is that getting on too? If it's a record player then what is it and what condition is it in? If it's had its time, then perhaps the speakers aren't where you should be looking.
You mentioned having heard the 685s in a shop. I'll bet it wasn't with your CD/amp. If it was, then at least you'll have heard something reasonably comparable (the room being the only other question mark), but if not, the shop's electronics will have been a completely different kettle of fish and could account for everything you heard. If you decide you really want to change speakers, then you should really take in your equipment to do direct comparisons against your AEs.
Regards,
Frank.
Username: Stu_pitt
Irvington, New York
Post Number: 3350
J.,
IMO, there's no point in tracking down all these speakers and spending the money if you don't settle the room issues. They'll sound great in a shop or in a room that's conducive to good sound, but at the end of the day you'll be disappointed all over again.
I also agree with Frank's post.
If you're looking for a great book shelf that's not too expensive (depending on your market of course), check out Audio Physic's entry level Yara line. I don't know your gear, but Yaras are pretty easy to drive and sound large, full, and excellent to my ears.
Username: Exerciseguy
Brooklyn, NY
United States
Post Number: 2737
Just throwing it out there http://reviews.audioreview.com/blog/wharfedale-evo-2-10-bookshelf-speaker-user-r eview/
Username: T_bomb25
Dayton, Ohio
United States
Post Number: 2213
The RS3 is very very nice.
England
Post Number: 763
Thanks for the replies here.
Looked at the NHT classic 3s, I really cant say I'm a fan of the looks Dan.
The Rega RS1s however are an option! And affordable. The RS3 arne't since I dont have the space to accomodate floorstanders. In September I'll be taking these to university with me and they NEED to be standmounts/bookshelfs since the room will only accomodate this.
To amazement, my neo 1s only come in at £200 retail, today you can get them for about £150 which is superb imo.
The dreamcatchers are another possibility fo sure, little expensive for me though atm. I look for the best deals I can get, I only ended paying £85 for my current speakers ;)
The Yaras are pretty difficult to track down Stu, but they're German so certainly an option. But like you said the room issues will always play a roll, so perhaps sticking and being happy with what I have is the best solution.
Already read the review Chris. I was bored too one day :P
Frank, how did you mean by saying the A60 was likely shot? You'd be amazed what this thing can put out clearly. I replaced the fuses when I got it to give myself a piece of mind and the insides looked in very clean nic. Mechanically there are no problems touch wood!
Brooklyn, NY
United States
Post Number: 2738
The Dreamcatchers are very good, great detail, fast, coherent, and deceptively large sounding; as are the Monitor Audio Radius R90 which are currently being closed-out in the States (along with the rest of the series), still the one of the very best small speaker I've ever listened to or laid my eyes on.
Wharfedale doesn't do it for you Jarvis, I'm sure you've seen Art's thread?
Username: Artk
Albany, Oregon
Post Number: 10095
Since you mentioned them and recommended them Chris am I to assume that the Wharfedales do it for you?
Brooklyn, NY
United States
Post Number: 2739
I'm not ready to comment yet on the EVO2-10, but they are beautiful (even in Maple) and the build-quality seems to be all there.
You seem to love them (and I respect your opinion Art), and the review I posted seemed to concur with your general description & others that I've read, so they would seem to be a reasonable suggestion & certainly worth a listen along with the EVO2-8.
England
Post Number: 764
I honestly think the dreamcatchers are too small, they're smaller than my current speakers. If anything that'd be a step back.
Read all of that dedicate post on the Wharfedales. I wish I could get them for a good deal, but I'm sure wharfedale will release a new version or equivalent which will be even betterer. On that note, Wharfedale Diamond 10 series is nearly out you know!
After having owned a radius r45 system and hating it so much I sent it back 2 days later, I dont have much faith in wanting to try the r90s I'm afraid.
There is also a new Monitor Silver line out in September, think they're starting around £400.
Brooklyn, NY
United States
Post Number: 2741
That R45 was just too weird a design, the R90 was very well executed, however it is very similar to the Dreamcatcher in many ways, including it's diminutive stature, so let's move on.
There's always something new around the corner, so what are you leaning towards?
England
Post Number: 765
I see, I'll give it that, it had a tweeter on the rear. They just sound tinny!
I like the idea of the RS1 from rega so I may go about trying to find that for a listen at some point, however I do want to hear the new MA silvers when theyre out.
England
Post Number: 766
I've decided I'm definately waiting it out until September after what I've just found about the new Silver Range from MA.
I hope its affordable!
Brooklyn, NY
United States
Post Number: 2742
Care to share that new MA Silver info with the rest of us?
England
Post Number: 767
I swore not to! So I cant tell you that theres now two standmounts, the range is called RX and the RX2 has an 8 inch driver =D.
Shh.
Username: Gavdawg
Albany, New York
Post Number: 1273
J.
What about Mirage?
I am not sure if you have heard any of their new designs, but they throw a positively massive soundstage, and IMHO are placement friendly. While some people will say they are a higher end Bose, I believe that they are a good speaker.
I really enjoyed the older towers. They had a smooth, dark sound with deep, wide soundstage.
Username: Gavdawg
Albany, New York
Post Number: 1274
I know as of late they have gone home theater, but the om design series treads the line between midfi and the high end.
http://www.miragespeakers.com/na-en/tags/om-design/
Berkshire
UK
Post Number: 3678
JJ, the A60 is getting on for 30 years old. Everything ages. If the amp hasn't been serviced (and I'm not sure who does this on A60s nowadays), then the output capacitors will be toward the end of their life, the output transistors will be working below their optimum level (at a minimum) and the general condition of the amp's components will be 'not what they once were'. Sure, it might still sound good, but for how long? So, in the choice between replacing nearly new speakers and replacing a 30 year old amplifier, I'd choose the latter, any day of the week.
If you spend your cash on new speakers and then your A60 gives up the ghost, you could try to have it repaired and if that doesn't work where will you be?
Sorry, just saying it as I see it...
England
Post Number: 768
Mirage doesnt take my fancy, they look small and breakable!
That metal driver and tweeter combination is sure to sound forward and bright, something I wont like.
Frank, I didnt know that, I presumed that the visual state of the a60s components would speak for themselves.
It looks like I'll have to give this a re-think. I've already made my mind up that I'm sticking with the speakers and seeing what MA have to offer in a couple months.
But perhaps a new amplifier would be a smart choice and give that little extra umph!
Time will tell, maybe ill replace both when money gives way.
Marantz PM 6003 may be an option here, I liked the 6002 for its musicality but not for its slightly bloated bass.
England
Post Number: 770
I took the chance with some mint condition Kef Q60s. Paying for them on the 15th (off to a festival soon and currently stuck in the house looking after sis til I got to the festival). Should get the speakers a week or so after. Man I cant wait, 8" drivers! Tradeoff is they're in black wood!
I'll let my current amp have a try at them and if its a no go I'll save for a new amp.
England
Post Number: 771
A sample picture of one I found on the internet (pics seller took were a bit shoddy).
http://3.bp.blogspot.com/_WeC7--3HfTI/Sj1XmIhbyDI/AAAAAAAAAKw/8Fgbr587jLI/s1600- h/IMG_2472.JPG
Username: Nuck
Post Number: 12876
A rear firing port is going to be difficult, JJ.
England
Post Number: 772
It has a front firing port! The driver and tweeter are are the top in a uni-q arrangement and the port is at the bottom! Its just an unusual pattern around the port.
Berkshire
UK
Post Number: 3682
The A60 should cope with the KEFs quite easily. They're not difficult to drive. I hope you like them.
Surprised you went for them of course...
Username: Kbear
Post Number: 152
You guys were talking about Mirage. I've heard a lot of different speakers over the last two years. For all the comparisons made between different models by audiophiles, I have found that almost all of them are excellent. Different presentations of course but I can get enjoyment out of just about all of them. I think the myriad of hifi companies are all capable of producing great products over their entire line most of the time and perhaps differences in quality are exaggerated.
Do you sense a "but" coming? Mirage was one of only two speakers that really stuck out to me as having bad sound. I listened to one of their tower speakers and found it to be very harsh. Must have something to do with their unique tweeter set up. Same thing with a pair of Paradigm Monitor towers. These are probably the only two speakers where right away I knew I hated the sound. Forward and bright speakers don't bother me per se, these two in particular just sounded very rough.
England
Post Number: 773
"Surprised you went for them of course..."
In what sense, just generally didnt expect such a move?
My motivation was driven in that if i replaced the amp I would still be stuck with the problem of music sounding thin. So a larger cabinet and driver from a renouned range and company may do the trick with the budget I have.
I'll let you know what I think in a few weeks when its set up and if your're lucky, maybe a pic or two!
Dan, Im glad you confirmed my suspicions about Mirage!
Username: Artk
Albany, Oregon
Post Number: 10126
The latest two incarnations of the Paradigm Monitor series have very few highlights and a whole lot of downside. The Atom Monitor being the best of the series...still.
Username: Nickelbut10
Post Number: 2621
Atoms and 7's. Thank god I got my V3's and V4's.lol Good theater sound indeed. Not so much for music.
Username: Gavdawg
Albany, New York
Post Number: 1278
have to agree with Art once again...
And with the Mirage speakers... I haven't heard the new stuff (aside from the OM Design bookshelf, which had a huge soundstage, but the KEF and Paradigm are more to my likeness)
The towers I was talking about were called the OM series. Heard these about 5 years ago and loved the sound. Of course, they have been discontinued.
I can't recall which one it was that I listened to.
Berkshire
UK
Post Number: 3692
JJ
Yes, just didn't expect such a move. Expected you to look at what we were talking about, go for a demo and actually listen to something before buying anything. Your reasoning makes sense to a certain extent. I just hope it proves to be the case.
Frank.
Username: Stu_pitt
Irvington, New York
Post Number: 3365
Gavin,
Was it the tower in Tweeter in Crossgate Commons? I can't remember the model either, but that was a very good speaker. It was a bipolar speaker with an angled front baffle IIRC.
I almost bought them, but they wouldn't have worked out in my room at the time. Maybe a blessing in disguise because they'd have been even worse in my current room. But in the right room, they were superb IMO.
Username: Gavdawg
Albany, New York
Post Number: 1280
yes it was stu!
I used to go in there frequently. My current system is from Hippos. I am sure that is a familiar name as well :-). Great service and staff with fantastic brands to choose from. Even the wife will go there with me.
I did a bit of Mirage related research this afternoon and think it was the OM 5.
Username: Stu_pitt
Irvington, New York
Post Number: 3368
It was the Mirage OM-9.
http://www.hometheaterhifi.com/volume_8_2/mirage-om-9-speakers-6-2001.html
I've been to Hippo's many times. My NAD 320BEE/523 CD player/PSB Image T55 system came from them,as did some other misc stuff. Very knowledgable and courteous people.
My only criticism is that they don't have a very good 2 channel demo room anymore. That one room is too small, has too many speakers, and doesn't have a chair in it. The demo rooms have turned into home theater rooms.
Not their fault, they're following the market. Their smartest move? Carrying Sony stuff. They advertise it a bit cheaper than Best Buy type places to get people in the door. Love it or hate it, it keeps their doors open, and people come in for Sony stuff and end up hearing real hifi stuff. Genius if you ask me.
Post Number: 2625
That is Genius indeed.
Username: Gavdawg
Albany, New York
Post Number: 1281
yup! in that room they have B&W 802D with Mac gear.
A far cry from Sony :-D For the most part, they have something for everybody there.
Towne TV in Rotterdam is a Paradigm studio dealer. Not sure if you have ever been there.
I was highly disheartened that they were driving them with Sony ES gear (why does everybody spooge over sony?). Even so, they had the Paradigm richness that I have come to love.
Username: Stu_pitt
Irvington, New York
Post Number: 3388
I haven't been to Towne TV, but have heard about what you're saying. The guy who used to run Clark Music was complaining about them. Appearently, a few people demoed Paradigm speakers in his shop, then went to Towne and got a low ball price, only to come back to Clark Music and ask them to beat the price. Towne was offering them for about 15% above cost to some people. Towne could afford to do that because they sell a bunch of other stuff like appliances.
The guy at Clark called over and spoke to the manager who didn't know it was going on (supposedly). They stopped discounting them.
I miss Clark Music. The guy running it was a great guy and got screwed over buy the owners. They wanted him to increase sales and marketing, yet didn't give him any money to advertise. How messed up is that? They finally gave up on the audio side of things and just sell pianos in a new shop. Too bad.
Username: Gavdawg
Albany, New York
Post Number: 1282
According to the clark website, they still sell hifi components (must be the site in 'Cuse). First time I went in there I was highly impressed. They had an awesome maggie setup with Mac components. I went to college at SUNY Oswego, and would venture down to Clark in 'Cuse. That was how I was first introduced to planar sound, and why I bought the MMG.
I concur with the Towne TV price not being prudent. I made it obvious that I was just auditioning, and not in the market... but that if I liked them enough I might bite.
I threw the card out with the price quote on it (it was for both the studio 20 and sig s1) but I do remember that it was $150 or so less than MSRP.
I wouldn't say they stopped discounting them! They had a big sign with "closeout" on it with the v.5 or v.4 monitors on it, advertising the MSRP, and then in red what they were selling it for.
Username: Stu_pitt
Irvington, New York
Post Number: 3390
You're correct, the Clark in 'Cuse still carries gear. The Albany area one (not sure where anymore)doesn't.
Home > Message Board > Home Audio > Speakers > Archive through August 16, 2009 > Need B&W 685 opinions [ « Previous ] [ Next » ]
