Thread: Any Good Outdoor or Wireless Outdoor Speakers? |
Bronze Member Username: Pbdr
Post Number: 99 Registered: Apr-05
| Posted on Friday, June 26, 2009 - 10:22 am: |
I'm looking for a good pair of speakers to use with my home system for my deck. So outdoor speakers definitely, but I'm also wondering if it's possible to get decent wireless speakers for outdoor use as well. So recommendations on 1) wireless outdoor speakers and 2) outdoor speakers in general. Preferably <$500 for both categories. Thanks. |
Platinum Member Username: Nuck
Post Number: 12744 Registered: Dec-04
| Posted on Friday, June 26, 2009 - 03:27 pm: |
Check out Cambrige, as well as Advent(made by somebody else). |
Gold Member Username: Nickelbut10
Post Number: 2612 Registered: Jun-07
| Posted on Friday, June 26, 2009 - 07:24 pm: |
Here is three different types Paradigm make. Just to throw out another idea. Their Rock speakers are neat. http://www.paradigm.com/en/paradigm/speaker-type-outdoor-marine.paradigm |
Platinum Member Username: Insearchofbass
York,
Pennsylvania
Post Number: 11722 Registered: Jun-04
| Posted on Friday, June 26, 2009 - 10:42 pm: |
Actually ive had the smaller advent speakers and I wouldnt recommend them for this project. They are made by Jensen by the way. |
Post Number: 12764 Registered: Dec-04
| Posted on Saturday, June 27, 2009 - 07:52 am: |
remember that we are dealing with 2 different types here as well. Outdoor speakers are fine, wireless are amplified speakers, sooo... Boston makes some wireless speakers as well, and they do small speakers pretty well. |
Gold Member Username: Gavdawg
Albany,
New York
Post Number: 1276 Registered: Nov-06
| Posted on Thursday, July 02, 2009 - 11:31 am: |
Klipsch makes a bunch of different outdoor speakers, an outdoor subwoofer, and a "rock" speaker. http://www.klipsch.com/na-en/products/outdoor-speaker/ |
