Home > Message Board > Home Audio > Receivers > Bose Lifestyles model 5 music Center ...
Author Thread: Bose Lifestyles model 5 music Center with Acous. 25
Username: Tomecat
You all are so great to be helping everyone. My Bose model 5 music center with the Acoustimass 25 system all of a sudden a load snap throught the speakers and then no sound. This happens more and more now. I power off and turn back on and it may work for a while but then snaps load in the speakers. Is this repairable? What did this happen? Thanks for any info. Tom
Username: Nuck
Post Number: 12595
Welcome, tom.
You might want to look at the cables and wiring, as much as can be serviced (I don't know what that entails).
Cheers!
Username: Frank_abela
Berkshire
UK
Post Number: 3661
Correct. Check all your connections first. Then check the wires to see if the cat (or any other unwelcome freeloader) has chewed through it. If all looks good, then the problem is in the main unit and you need to send it off to your local repair centre.
Username: Dmitchell
Ottawa, Ontario
Post Number: 2655
Good point Frank. I thought that one of my speakers in my dining room was blown (static and distortion). Turns out the cat had chewed through the speaker cable.
Username: Nuck
Post Number: 12610
But that's a welcome freeloader...
Username: Dmitchell
Ottawa, Ontario
Post Number: 2657
Depends who you ask.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Audio > Receivers > Bose Lifestyles model 5 music Center ... [ « Previous ] [ Next » ]
