Thread: Apple Lossless |
Bronze Member Username: Ezntn
TN
Post Number: 15 Registered: Apr-09
| Posted on Saturday, June 06, 2009 - 05:51 pm: |
iTunes provides a command to convert mp3 files to Apple Lossless. It seems, depending on file type, one's choices are limited. Under preferences, one can choose one of 5 format protocols to import music. These are: AIFF Apple Lossless MP3 AAC WAV I've read elsewhere on this forum that Lossless is preferred. I stream iTunes via Airport Express to my home system. Just picked up a 1 TB portable HD to store all the music on. Transferring iTunes to the portable HD was seamless. Am I missing something here? Does not mp3 compress the music, hence the smaller file size? I would think that the data lost during the compression is just that, lost. So how can converting to lossless format recover that lost information, or is that happening. Converting is a breeze, and so very much quicker than burning the entire CD to whatever format. What's my best option here? Or .. would a music server attached to the home system provide the best option for storage of all this music? |
Silver Member Username: Magfan
Post Number: 484 Registered: Oct-07
| Posted on Friday, August 21, 2009 - 01:25 pm: |
I Import using Apple Lossless. I convert them to MP3. Pointless to go the other way. Than, I make multiple, matching playlists, one of the Lossless for home use, the MP3s go to portable stuff...Ipod or 'Touch. Now, what kind of link from the Airport to your Stereo? Analogue or Optical? |
