Home > Message Board > Home Audio > Receivers > Need Advice on Which One
Author Thread: Need Advice on Which One
Username: Nholmes8669
I am looking at 2 different recievers for my cabin up north. I found a pioneer vsx-505s and a pioneer vsx-605s both on craigslist for a decent price. My question is which one do you guys think is better and why? I can get the 505 for 65.00 and the 605 for 75.00. Thanks
PS I am running a pair of cerwin vega re 30 12" speakers....will either of these receivers handle these 4 ohm speakers?
Username: Jan_b_vigne
Dallas, TX
Post Number: 13655
You really can't decide whether to spend $65 or $75?
Its not that I dont want to spend the money I was wondering which one was better and how?
Dallas, TX
Post Number: 13657
One has more features.
Dallas, TX
Post Number: 13658
And I wouldn't pair either of these with a four Ohm nominal load speaker.
Spend just a bit more cash.
Ok what would you recomend? Not looking for something real expensive...thanks
Dallas, TX
Post Number: 13659
I have no idea. I haven't had anything to do with inexpensive receivers in decades. Why not start by buying an amplifier that indicates it can drive a four Ohm load?
Yeah I will look into one. But, don't ya need a receiver with a pre-out for an amp? I dont think most inexpensive recievers have these do they?
Username: Nuck
Post Number: 12519
Sure, nh, lots do, just have to check the models.
The last few Harmon Kardon models I saw had them.
Dallas, TX
Post Number: 13660
No, I probably shouldn't have typed "amplifier". The "power amplifier" is one portion of a receiver and it determines what the "receiver" will drive in a speaker load.
I'm not suggesting you buy a separate power amplifier if you aren't interested in the highest quality sound in this location. However, if you are not in need of a tuner function, you might consider one of the entry level NAD integrated amplifiers. They are a fair amount more than $75 though.
Otherwise, begin your search by finding out which receivers claim they can drive four Ohm loads. If you use this system as background music only - no loud volumes - then you can get by with a receiver that indicates it can drive a six Ohm load. An HK is a good place to begin. If your intention is to party, then you should be looking at a reasonably stout power amp whether it's built into a receiver, and integrated amp or a separate unit.
Username: Nuck
Post Number: 12524
If you can keep your hands away from the Bass knob, a decent HK might play them ok.
Username: Nuck
Post Number: 12525
10 yrs ago I had an HK AVR50 that handled low impedence speakers easily.
I'll have to check those out, thanks....
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Audio > Receivers > Need Advice on Which One [ « Previous ] [ Next » ]
