Home > Message Board > Home Audio > Amps > Cardas vs. Audioquest vs. Kimber
Author Thread: Cardas vs. Audioquest vs. Kimber
Username: Dmitchell
Ottawa, Ontario
Post Number: 2578
First of all, I know I should post this in the cable section, but no one ever seems to look there, and I wanted to get your guys' opinion.
I'm tossing around the idea of changing my interconnects between my MA6300 and CA 640C CDP. As some of you remember I am currently using Blue Jeans IC's. I was interested in trying out something new.
Before you guys ask (Jan) what it is I dislike about the current sound, let me say that I think it sounds pretty darned good. I like experimenting and changing things up often.
I was looking at either Kimber Heros, Cardas Crosslinks or Audioquest King Cobras. As you can see, I don't want to spend too much money ;-)
Thanks!
Username: Stryvn
Wisconsin
Post Number: 1131
Have you tried any of the diy stuff, David?
Username: Dmitchell
Ottawa, Ontario
Post Number: 2583
No I haven't Stryvn. I want to, just can't seem to find the time to take on even a small project right now.
Username: Dmitchell
Ottawa, Ontario
Post Number: 2584
I've read a fair bit about Anti-Cables, and I wouldn't mind trying a DIY anti-cable type thing. Anyone know a good place to order insulated magnet wire?
Username: Soundgame
Richmond Hill Toronto, Ontario
Post Number: 772
Dave, is there anything specific that you're looking for in changing the IC? Is it more detail you're after or broader soundstage, deeper soundstage.
I'm using the Ultimate Cables that the guy from Quebec sells on CAM. For about $55 you can get a 3ft cord which is 50/50 copper and silver, cryogenically treated with Neutrik connectors. He'll upgrade the connectors to Vampires for $15. That's the insured shipped price, taxes-in. I found they give me a very smooth top end and good bass. They have a little less detail then magnet wire cables but less noise and a deeper soundstage. If you don't like them, I'm sure you could easily flip them for half the cost and you wouldn't have lost much.
Username: Soundgame
Post Number: 773
Oops, price went up slightly but drop him an email. He's friendly and negotiable.
http://www.canuckaudiomart.com/details/127276-ultimate_cables_silverseriesc4_1pa ir_1m_wneutrik_rca_/
Username: Dmitchell
Ottawa, Ontario
Post Number: 2586
Not sure what I'm looking for George. I'll know it when I hear it :-)
Thanks for the tip on the Ultimate Cables. Checking them out right now.
Username: Dmitchell
Ottawa, Ontario
Post Number: 2587
I'm also considering checking out Unity Cables. They're located right here in Ottawa.
http://www.marketworks.com/storefrontprofiles/deluxeSFshop.aspx?sfid=78796&c=148 915
Username: Soundgame
Post Number: 774
Yeah I've seen the adds for Unity Cables and been to their site but don't really have any information.
Username: Artk
Albany, Oregon
Post Number: 9590
van den Hul - The Well Hybrid or better.
http://eugenehifi.com/
Sale items
http://eugenehifi.com/Demo_Specials/Demo_Used_Specials.htm
vdH cables
http://eugenehifi.com/VanDenHul/htm/van_den_Hul_RCA_Cables.htm
Call these fella's they'll let you audition the cable...very little risk. Only problem may be the Canadian connection...even then maybe they can point you in the right direction.
Username: Mike3
Wylie, Tx
Post Number: 1958
David, the DIY cables I sent to George had $5 RS RCAs on them. The were 3 or 4 generations of cable better than the King Cobra in my kit.
Radio Shack has the magnet wire. Then again so do I. I also have .999 pure silver wire. If you want me to send you enough to build your own DIYs let me know the lenght. IMO the Eichmann Bullets, non-silver, are much better than the RS RCAs. I have a contact for them. PM me if interested. If you can solder you can have a sweet set of ICs on the cheap.
George's find seems pretty good since I am familiar with what the MIT II ICs did for me which I liked better than the DIY magnet wires. It seems George found another builder that does something similar.
Username: Jan_b_vigne
Dallas, TX
Post Number: 13617
Magnet wire is insulated, it uses the epoxy coating as the insulation so there is no conventional dielectric. Scrape the epoxy off the end of the wire with a razor blade and make your DIY's.
You can actually use just one conductor leg from RCA + (center pin) to RCA + (use the RS no solder/screw type RCA's for a quick try and best sound for a cheap RCA). Then run another conductor from any chassis screw on your CD player to a ground screw on your integrated. Use a meter to assure a solid ground at the CD player's chassis screw. That makes a solid connection with minimal fuss. For less then $10 and ten minutes time you have a very decent ic IMO.
I agree the Eichman's are better than the RS RCA's but will require some soldering skills and no connector is better than the Eichmans but far more trouble.
Otherwise, my only advice would be to not seriously consider the Kimbers as they do not IMO have a similar balance to the Mac. After that, the cable decisions are too numerous.
My strongest suggestion if you opt out of the DIY's is to avoid thick cables and audio jewelry RCA's. Go minimal in both areas.
Username: Stu_pitt
Irvington, New York
Post Number: 3295
How would you describe Kimber's balance, Jan?
Interesting thread, Dave. I have the King Cobras. Mike replaced King Cobras with the magnet wire. If I recall correctly, he said they were far more open sounding, among other things.
I don't have too much experience with different cables, so I'm following the thread. Obviously, the only way to really figure out what works best is to audition the stuff. From what I hear, Cardas gets most things right, but isn't very musical or engaging. Same for Nordost.
Dallas, TX
Post Number: 13619
Kimber gets my vote for a good all round cable that is frequently a safe bet. However, IMO Kimber will do best with systems that prefer a touch of something extra that places them in a higher category of sound - the sense you are hearing more than you really are. I don't think the Mac needs this extra and will only be poorly served by this cable. With Bryston or Rotel I wouldn't think the Kimber would be a poor match as far as what all the pieces are trying to achieve and would tend to compliment what priorities a Bryston or Rotel buyer might have.
I do like the Kimber overall but just not in this system.
Username: Nuck
Post Number: 12406
Fair nuff.
You had some Kimber in the big box O' cables in the closet then, huh JV?
Dallas, TX
Post Number: 13621
Yeah, I have some Kimber, and some Sumiko and some OCOS and some Monster and Audioquest and MIT and god knows what else. But I was buying those at store cost and sometimes being given a cable to try. I got off the cable merry go 'round years ago so none of those are current versions of anything.
Username: Nuck
Post Number: 12414
I suppose a bottle of premium Scotch will be a good trade for your lasgana, your middle seat for sommore Chuck Berry and a few cables to go??
LOL
Username: Nuck
Post Number: 12415
I have to think that the most minimalist cables are the starting point, David.
I will start from there.
I think George had noise issues due to the 1$ plugs in the cables that Mike and I put together.
Username: Dmitchell
Ottawa, Ontario
Post Number: 2592
Thanks for all the input guys.
I'll heed Jan's advice and steer clear of the Kimbers for now.
Jan, so when you say to stay away from the thick cable, do you mean for speaker cable or for IC's, or both?
I'm sorta leaning towards George's suggestion right now.
Username: Nuck
Post Number: 12418
Thick cable meaning pretty and thick, David.
It just doesn't matter man.
But minimalist can be les than pretty, too.
Username: Dmitchell
Ottawa, Ontario
Post Number: 2593
My dealer always uses speaker cables the diameter of garden hose. I always thought they looked cool, but then again, I'm attracted to bright, shiny objects too.
Username: Soundgame
Post Number: 779
Dave, I'm trying a PS Audio Xtreme Speaker Reference that a friend lent me. These are garden hose thickness with all the fine jewelery. The went for about $800 when they were first released about 5 yrs or so ago. I've tried them against my Kimber 4PR on first the low frequency terminals and now on the high frequency terminals and other then what a would say the slightest impression of more openess...nadda. No way I would spend that kind of money for a difference that I'm not sure is even there.
On another note, yeah the DIY IC's provided great detail and an airy sound but not a lot of body or smoothness plus yes, I did get noice but I suspect that's because they don't have a drain wire wired in and I'm getting some feedback. Nuck/Mike...did you ever think aoout building them with a drain wire?
Mike - you got me thinking about an all silver IC again. The IC's I'm using now 50/50 copper/silver mix are very smooth with good detail and body...I'd say very balance but not as much top end detail as the magnet wire...which is what I love about the DIY IC's. I wonder if a DIY silver cable with a drain wire would get rid of the noise problem and take it to even a higher level???
It's all fun.
Dallas, TX
Post Number: 13638
What sort of noise are you hearing?
Username: Soundgame
Post Number: 782
Hi Jan,
At power up you get a hum on the speakers which continues at a much lower level once you get a signal from the source. Once the music is playing, it's virtually unheard unless you go right up to the speakers and listen carefully. It could be the fact that my Bryston 3B-ST itself has a mechanical hum and these cables are just so sensitive that they highlight the fact that there is noise in the line.
Username: Nuck
Post Number: 12459
Or it might be the way Mike and I made them on the counter, i think we fixed it once.
Dallas, TX
Post Number: 13642
Try switching back to a shielded cable of any kind - good, bad, cheap or not, just a shielded cable to see if this isn't the issue. From what you're saying you simply need a shield on the ic.
Username: Soundgame
Post Number: 783
Yes, when I use my new sheilded cables the hum in the line is gone - totally but there still is the mechanical hum in the amp.
As mentioned, the magnet wires seem to provide all the details but are "more" susceptible to hum/feedback. Seems like it just follows the standard rule that nothing is perfect and there are always compromises.
Username: Dmitchell
Ottawa, Ontario
Post Number: 2615
I've got a mechanical hum in one of my Brystons too George. Not loud enough to hear with music playing, but if you go close to the rack you can hear it.
Username: Soundgame
Post Number: 785
Dave, in a quite room, from three feet away can you still hear the hum? With mine, I can, which is supposed to be the Bryston test for mechanical hum acceptabilty. I spoke to their service department and that's what they told me. I'm moving on June 6 - 9th and when I'm at my new temp. residence (parents basement), I'll see if it hums at their place. If it does, I'll be looking to ship it back to Bryston.
Username: Nuck
Post Number: 12511
Brystons make noise george, but always as low as you say.
Thats what I mostly heard from the amps.
It happens.
Username: Dmitchell
Ottawa, Ontario
Post Number: 2618
For me it's more like just a foot away, but definitely audible. Strangely enough, it was much worse when it was sitting on top of another Bryston.
Username: Stu_pitt
Irvington, New York
Post Number: 3318
My Bryston has never hummed.
Now that I say that, you know what'll happen tomorrow...
Dallas, TX
Post Number: 13650
"Yes, when I use my new sheilded cables the hum in the line is gone - totally but there still is the mechanical hum in the amp.
As mentioned, the magnet wires seem to provide all the details but are "more" susceptible to hum/feedback. Seems like it just follows the standard rule that nothing is perfect and there are always compromises."
Uh, ... no.
It means the DIY cables aren't shielded. That's all.
Username: Nuck
Post Number: 12515
Just pull another run of mag wire from the case along the length of the run and terminate it near the load end.
Username: Soundgame
Post Number: 790
Nuck, sounds like you're talking a "drain wire", which is my suspicion as to why the DIY cable makes noise. I'll have to do that and then recompare to my shielded cable. First, I gotta get moved out and settled into the new digs.
Dallas, TX
Post Number: 13652
The DIY's are not shielded. If you want a shield over the cable, you can build a moderately effect one with aluminum foil. Or you can buy a braided shield and insert the DIY cable into that. That does, however, alter some of the characteristics of the DIY cable.
Username: Mike3
Wylie, Tx
Post Number: 1985
One of the beauties of this particular DIY was it's minimalist design which JV has helped me understand that it leads to lower impedance. The goal being as little as possible to get in the way of the signal.
Username: Soundgame
Post Number: 792
I can hear that. I still have not given up on the sound it provided...it's infectious. Eventually, I want to try building an all silver IC, just to see what it can do.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Audio > Amps > Cardas vs. Audioquest vs. Kimber [ « Previous ] [ Next » ]
