Thread: Bypassing a Receiver |
New member Username: Mani6264
Post Number: 1 Registered: May-09
| Posted on Sunday, May 17, 2009 - 01:30 pm: |
I am planning to connect 2 Bang & Olufsen Beosound 8000 powered speakers directly to the variable out of my Bravia LCD TV. I am aware of missing out on surround sound but is there anything else I am missing? Is this a good/bad idea? Thanks. |
Platinum Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 13605 Registered: May-04
| Posted on Sunday, May 17, 2009 - 01:46 pm: |
. The quality could be better since the TV isn't a great source but otherwise, if you like the speakers, there is nothing technically incorrect about the set up. . |
Platinum Member Username: Nuck
Post Number: 12386 Registered: Dec-04
| Posted on Sunday, May 17, 2009 - 02:35 pm: |
Mani, do you have any options, such as a receiver etc? |
Post Number: 2 Registered: May-09
| Posted on Sunday, May 17, 2009 - 02:49 pm: |
Thanks Jan. Nuck, I can get a receiver if I have to but I am trying to minimize the components as much as possible. Thanks. |
Post Number: 12390 Registered: Dec-04
| Posted on Sunday, May 17, 2009 - 03:39 pm: |
Then plug and play, my friend Cheers! |
Post Number: 3 Registered: May-09
| Posted on Tuesday, May 19, 2009 - 03:12 pm: |
Thanks all. |
