Home > Message Board > Home Audio > Amps > Archive through July 28, 2004 > Converting bass amp....
Author Thread: Converting bass amp....
Username: Nufan
Hi i was wondering is there anyway i can convert my bass amp into a amp for my car stereo? i have a peavey mark IV 210watts at 4ohms and 310watts at 2ohms can anyone help me? i would really appreciate it if anyone could
andy
Username: Soccer
Post Number: 206
You'de have to open it and check the tension at the secondary of the transformers! If it's around 14Volts Ac, you can throw away the transformer(s) and rectification plates, and connect the rest to your car's power. (DON'T DO THIS AT HOME) Be sure you're handy with this kind of stuff!!!!
Username: Nufan
i dont really know anything about sound equipment for cars is there anything else i could do? i dont want to ruin my bass amp do u know that what u said to do will work for sure? and could u maybe give alittle more detail on what to do? thanx
andy
Username: Project6
Post Number: 880
If you don't even have the basic knowledge on how to work on electronics, leave it to the pros. or just buy a power amp for your car.
Home > Message Board > Home Audio > Amps > Archive through July 28, 2004 > Converting bass amp.... [ « Previous ] [ Next » ]
