Thread: Yamaha AV Receiver Drops Audio |
New member Username: Ddoerr
Post Number: 1 Registered: May-09
| Posted on Friday, May 01, 2009 - 05:25 pm: |
I have a brand new Yamaha receiver with 4 in, 1 out HDMI ports. I have hooked up my Scientific Atlanta Cable/DVR running into it via HDMI. I have an HDMI connection from the receiver to my Panasonic plasma as well. While watching TV, the video is fine but the audio (from the receiver) randomly drops out for a split second. It never drops out for more than a second or so and it is totally random no matter what channel I'm watching or how loud it is. I have tried switching to a different HDMI cable and that didn't help. Any thoughts? |
Silver Member Username: Mccambley
BREEZY POINT,
NY
Post Number: 650 Registered: Jun-05
| Posted on Saturday, May 02, 2009 - 12:50 pm: |
Check to see if this problem occurs while playing a DVD or other sources. If the problem only exist while using the cable box only try unplugging the cable box while it is on, wait 15 second and replug it in to reboot the box. If this doesn't work you could try component cables with a digital connection to see if the HDMI is not getting a good hand shake. |
Platinum Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 13552 Registered: May-04
| Posted on Saturday, May 02, 2009 - 04:55 pm: |
. Geez, when I was learning this stuff the gear we had would blow now it's got down to a handshake. There's no future for this hobby. |
Platinum Member Username: Nuck
Post Number: 12202 Registered: Dec-04
| Posted on Saturday, May 02, 2009 - 06:16 pm: |
hehehe |
Post Number: 12203 Registered: Dec-04
| Posted on Saturday, May 02, 2009 - 06:18 pm: |
Doug, iIwould be talking to my dealer about this, thats why you bought from a dealer, right? Or at least the store. |
Post Number: 2 Registered: May-09
| Posted on Sunday, May 03, 2009 - 01:40 pm: |
Believe it or not, I went with the "power down the DVR" option and it worked! I unplugged the unit for about a minute, plugged everything back in and haven't had any problems since then - knock on wood! Thanks! |
Post Number: 12210 Registered: Dec-04
| Posted on Sunday, May 03, 2009 - 01:57 pm: |
Is it programmed by Microsoft?? Good stuff DD! |
