Thread: HK Avr 330 Speaker selection? |
New member Username: Delirium
Post Number: 5 Registered: Jun-04
| Posted on Friday, June 18, 2004 - 12:02 pm: |
I just got a new avr 330 and I dont see any a/b speaker selection on it? Can anyone tell me if this receiver has this capability? Other receivers I have had in the past have always had this. Thanks. |
Bronze Member Username: Rickypearson
Post Number: 22 Registered: May-04
| Posted on Thursday, June 24, 2004 - 11:25 pm: |
Well If it Doesnt have it on the back then there no way to Do A/b Speaker Selection, Unless you run to your Local Electronics store and Buy a Small Box the Plugs in to you Main front Speaker Connection at the back and allows you to have a/b speaker slection |
Bronze Member Username: Goose
Post Number: 88 Registered: Feb-04
| Posted on Friday, June 25, 2004 - 12:10 am: |
What your AVR330 has is better than A/B switching. You can do multi-zone! Assuming, of course, that you only want 5.1 in the main zone, you can use the extra 2 channels of this 7.1 receiver for a second zone, with independent source and volume. Check your manual for details. |
