Home > Message Board > Home Audio > Subwoofers > Just bough Re Audio XXX
Author Thread: Just bough Re Audio XXX
Username: St_lunatic28
I just bought 2 12 inch re audio xxx subs. I dont know what amps i should run with these there dual 2 ohm subs. Does anyone know what amps would be good to run with these subs there 2000 rms 4000 max
Username: Nuck
Post Number: 12155
Crown amps.
I have to assume that you have spec'd the enclosure to fit in your listeing room.
Username: Mrskullz1
Brooklyn, New York
Post Number: 1191
which would most likely be in the trunk of his car
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Audio > Subwoofers > Just bough Re Audio XXX [ « Previous ] [ Next » ]
