Thread: Home system config inputs |
New member Username: Willow
Post Number: 10 Registered: Feb-04
| Posted on Friday, June 18, 2004 - 04:55 am: |
Hi. I am putting together a home system setup for a friend and would like your inputs. Application will be 60% Movies 40% Music Have a budget of around US$4 to 5K for receiver, speakers and dvd player. Room about 12 x 20 with high ceiling. Want to fix on the speakers first and am considering the following brands: PSB, Polk Audio, Def-Tech, RBH, Mordaunt Short or Paradigm – too many to chose from! I would like floor standing models for front left and right and bookshelves for rear and a sub to match. I live in Asia where most of these models are not freely available – especially to demo. So I will have to go with good advice on combinations and order the equipment to be shipped internationally. I am looking at Rotel, NAD and possibly HK/Marantz receivers with 6.1 and 50 to 100w RMS per channel. For DVD I am looking at the Denon DVD-2200 or Pioneer DV 45A. Could someone help with possible combinations and model numbers? Thanks.
Silver Member Username: Project6
Post Number: 833 Registered: Dec-03
| Posted on Friday, June 18, 2004 - 01:06 pm: |
With that budget, this is what I would buy. Paradigm Phantom Home Theater speaker package NAD T773 Denon DVD-2200 where in Asia are you? |
Bronze Member Username: Willow
Post Number: 11 Registered: Feb-04
| Posted on Saturday, June 19, 2004 - 04:21 am: |
Hi Berny Thanks for your inputs, Im based in India. Do you think the power of the 773 is required. I was thinking more like 763 or even lower, thus allowing more for speakers... |
Silver Member Username: Landroval
Post Number: 304 Registered: Feb-04
| Posted on Saturday, June 19, 2004 - 06:42 am: |
I also think you shouldn't waste too much money on the receiver. A T753 or T763 will be fine and you can get better speakers. The Denon 2200 is a good player if you dont require a DVI output for a projector/lcd/plasma screen. If you have one of those I suggest you get the Samsung DVD-HD931 with Faroudja DCDi for movies and maybe a Pioneer 565/575 for multichannel music. Also you might want to try a Pioneer Elite setup with the 55TXi receiver and 47Ai or 59AVi player and connect them with firewire. You'll get SACD/DVD-A via digital and from what I've heard the quality is great. The 59Avi also has a HDMI out so you'll be future proof for a while. I know none of those speakers very well, but about what I've read I'd say the Paradigm Studio series are quite nice. You might also want to check speakers from B&W (600/700 series), Dynaudio (Audience) and Tannoy (Sensys DC). For a sub I suggest you get a Velodyne, SVS, HSU or REL. |
Post Number: 12 Registered: Feb-04
| Posted on Saturday, June 19, 2004 - 07:43 am: |
Thanks Landroval. I will try and check out the Pioneer setup. I have a 742, so I do know what the NAD can deliver. |
