Thread: Question About Back of Speaker |
Bronze Member Username: Rickypearson
Post Number: 17 Registered: May-04
| Posted on Friday, June 18, 2004 - 12:52 am: |
On the Back of my Speaker insted of there Being just 2 Connections thers is 4 ( 2red, 2 Black) if i was to Hook you another speaker to each one would that affect the amount of pwer need and the amount of total Ohm Rating, and over time will this affect my system? |
Bronze Member Username: Natediggidy
Baltimore,
Maryland
U.S.A.
Post Number: 27 Registered: May-04
| Posted on Friday, June 18, 2004 - 01:57 am: |
Are the terminals (same color) connected by a thin flat metal bar? If so, don't do it! This type of hook-up is for bi-amping your speakers. Seperate amp for the tweeters and woofers. One set of terminals is for the tweeters and the other is for the woofers. |
Post Number: 19 Registered: May-04
| Posted on Friday, June 18, 2004 - 05:09 pm: |
Yeah there is a thin Flat metal Bar connecting it, so would u know how to Bi- amp the Speakers? thanks again |
Silver Member Username: Project6
Post Number: 847 Registered: Dec-03
| Posted on Friday, June 18, 2004 - 11:15 pm: |
here are some reading materials on the subject http://www.audiovideo101.com/learn/askus/displayas kus.asp?questionid=246&List=13 http://www.whathifi.com/newsMainTemplate.asp?storyID=59&newssectionID=3
