Thread: Capacitors |
Silver Member Username: Silvermopar
Nebraska
Post Number: 144 Registered: Aug-06
| Posted on Monday, April 20, 2009 - 11:13 pm: |
What is the benefit of them? At what point of current flow should you have one? Finally how many Farads does one need? |
Platinum Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 13524 Registered: May-04
| Posted on Wednesday, April 22, 2009 - 08:13 pm: |
. The benefit is they either couple or decouple a circuit, they either filter or store energy. You need to place a cap at the point where you want its action to take place. How many farads depends on how you're using the cap. If you are using it as a storage device, get as many as you can. But I bet you meant to place this in the "car stereo" section. . |
Nebraska
Post Number: 145 Registered: Aug-06
| Posted on Thursday, April 23, 2009 - 12:02 am: |
Yah, well i put it in subwoofers because there is far more traffic here than the other places. I guess I dont need a capacitor, but i have heard of them and seen several. Just never knew if one would be of any use to me. |
