Thread: Will this work for home use and will it pound? |
New member Username: Jodavis
Toronto,
Ontario
Post Number: 3 Registered: Apr-09
| Posted on Sunday, April 19, 2009 - 06:24 pm: |
Ok, so I have been looking into putting together a home subwoofer myself since most subs on the market are overpriced. I saw the perfect subwoofer that suit my wants. I found a nice 2,500wattRMS sub that I can use for my house which I will power it with 2 Crown amps down to 2 ohms. Don't worry, I will box this right for home use. My concern is how will this pound in a basement? Here is the link to the sub: http://www.parts-express.com/pe/showdetl.cfm?Partnumber=293-622 |
Platinum Member Username: Nuck
Post Number: 12116 Registered: Dec-04
| Posted on Sunday, April 19, 2009 - 07:57 pm: |
What do you need to know? You have the specs and the enclosure needs, you have chosen the amplification. Do you need approval? Build it and let us know. |
Silver Member Username: Mccambley
BREEZY POINT,
NY
Post Number: 647 Registered: Jun-05
| Posted on Sunday, April 19, 2009 - 08:03 pm: |
You mention price as a reason to build your own sub. After the cost of $800 for the driver, the cost of the amps, the speaker housing, and the interconnects where is the savings. Its not like you can just put this sub in just any box the build quality needs to be top shelf. I can't believe there are no good subs on the market in that price range. |
Bronze Member Username: Mike19
Tallahassee,
Fla
Post Number: 23 Registered: Jan-09
| Posted on Monday, April 20, 2009 - 09:04 am: |
Hi Julien. Do you think you can build a better sub than the $550 HSU VTF-2 MK3? http://www.hsuresearch.com/products/vtf-2-mk3.html |
BREEZY POINT,
NY
Post Number: 649 Registered: Jun-05
| Posted on Monday, April 20, 2009 - 01:59 pm: |
If you want to check out so supped up home made base read this article. http://hometheatermag.com/gearworks/1004GWsub/ |
Post Number: 12122 Registered: Dec-04
| Posted on Monday, April 20, 2009 - 02:30 pm: |
If the price ends up near a Fathom 113 sub, I would go with the JL. Hey, build it and let us know! |
Gold Member Username: Arande2
Rattle your ...
Missouri
Post Number: 2955 Registered: Dec-06
| Posted on Sunday, April 26, 2009 - 06:53 pm: |
AudioPulse is very good One thing that's really important to understand is how important the enclosure and amp are.. Example: System A: Your Sub Choice, Enclosure: Some random large sealed box. Amp: 2kW System B: Same Sub as A, Enclosure: Ported box designed for efficient flat response in YOUR ROOM to 30hz, well-braced, etc... Amp: 2kW System C: Same Sub as A, Enclosre: Ported box designed for less efficient flat response in YOUR ROOM to 12hz, well-braced, etc... Same Amp System A would end up sounding like the driver and add some distortion depending on the box. System B would end up being a lot more efficient (louder) and help lower distortion in some ways, but add distortion around the port tuning.. System C (my choice) would be of similar efficiency to System A, except it would extend to a much lower frequency. For the same amplifier power input, the driver would be moving different distances at the frequencies affected by the boxes (below 50hz) So it really depends on what you want from the system.. If what you want is just LOUD independent of frequency, you'd be better off with a more efficient pro driver like the Aurasound NRT-18. If you want LOUD down to low frequencies (think movies, or organ music, or synthesized music..), you'd be making a good choice with that 15", or EVEN better choice with an 18" driver or pair of 18" drivers with a lot more displacement capability AND power handling AND of course the needed specs to go low.. Just blabbing Arande |
Silver Member Username: Magfan
Post Number: 429 Registered: Oct-07
| Posted on Tuesday, April 28, 2009 - 10:15 am: |
For the REAL overachiever. http://www.passdiy.com/pdf/el-pipe-o.pdf Game set and match: |
Rattle your ...
Missouri
Post Number: 2956 Registered: Dec-06
| Posted on Tuesday, April 28, 2009 - 05:01 pm: |
Oh yeah I've read that a couple times before Not very common  |
