Home > Message Board > Home Audio > Subwoofers > Choosing a subwoofer enclosure
Author Thread: Choosing a subwoofer enclosure
Username: Jodavis
Toronto, Ontario
Hello, I'm building my own subwoofer for a basement I will be moving to. I don't have any idea on the right enclosure for home use. How do you get the right box for a sub? Here's my future sub:
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=293-622
Username: Mike19
Tallahassee, Fla
Post Number: 20
Hi julien.
Please do not take this personally, but if you do not know what enclosure to use for that speaker, then maybe you do not have enough experience to build your own sub.
Mike
Username: Dmitchell
Ottawa, Ontario
Post Number: 2455
There's plenty of info out there.
http://www.diysubwoofers.org/
I think Julien is up to the task.
Username: Magfan
Post Number: 425
DVC and 2 ohms each, at that? Boy, you need to talk to Andre about an Amp! And a power supply......hint hint.....to make it all happen.
Beware structural damage when cranked up.
Username: Jan_b_vigne
Dallas, TX
Post Number: 13525
Parts Express will help you with the correct enclosure volume and port size. You would probably be wise to order one of their prefabricated enclosures and not mess with building a box yourself. Call their tech services department.
Username: Magfan
Post Number: 426
Madisound also sells a line of plate amps.....
But, Jan, doesn't a pair of 2 ohm VCs raise an alarm?
You could always wire them in series!
Username: Nuck
Post Number: 12151
Granted it looks like a killer, but how did you decide on this particular driver Julien?
Have you shopped some higher end subs already?
Username: Magfan
Post Number: 428
Nuck....I looked up this driver and it is pretty pricey....so much so that he could get a HSU VTF3. I think we have another Andre here, and he wants realistic jet plane takeoffs, right in his own living room.
Too much is never enough, I say.........
Username: Nuck
Post Number: 12156
I might be tempted to go with pro amps for this job!
Maybe Crown amps on each coil...
Username: Nuck
Post Number: 12157
Nothing says excess like overdoing it!
Username: Arande2
Rattle your ...
Missouri
Post Number: 2954
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Audio > Subwoofers > Choosing a subwoofer enclosure [ « Previous ] [ Next » ]
