Thread: Sony Equalizers |
New member Username: Landoco
Yonkers,
NY
Post Number: 1 Registered: May-04
| Posted on Tuesday, June 15, 2004 - 05:52 pm: |
I have a Sony 444ES receiver which has, I am told, an excellent equalizer. However, I am not sure how adjusting the equalizer affects your speaker sound. For instance increasing the treble to the upper limit of the KHz band does what to the high frequency? Does it make the treble more forward or bright? Also, how about the mid range and bass? I find when I turn the mid range up to the upper limit of the range it makes that frequency more forward and a lot more detailed. Anyone, just a quick education on how to use an EQ band to improve speaker performance. Thanks
tommy_c_p2 Unregistered guest |
| Posted on Saturday, June 19, 2004 - 06:05 am: |
Im just a reader here, I just wonder I know alot about sound but when i come to this forum I'm notice that I known nothing . so i just read and learn.. Im not sure what you mean by improve speaker performance but If I had you system i just config to comfort my ear. |
