Home > Message Board > Home Audio > Phono > Starter Kit ?????
Author Thread: Starter Kit ?????
Username: Iangeke
Toronto
Im just start to thinking of setup a turntable and done a little research...
im thinking of buying a project debut 3, and a hk 3485 with a av123 xls is like the best cheap system, but then im totally lost on the other stuff, can anyone give any suggestion plz? also for any other reciver and speakers.
also one thing i dont understand is, does a turntable has to have a stereo system? is there any turntable dont need a backup system?
because im just a student and like to move a lot, not buying these would save me both money and the trouble to move them...
if its not the case i might to rethink the whole idea, or start to change my lifestyle...
thanks
Username: Nuck
Post Number: 12037
As a vagabond English Lit major, you may just want to consider that lifestyle change.
Username: Soundgame
Richmond Hill Toronto, Ontario
Post Number: 743
A turntable that has build in speakers and amplification wouldn't be worth pusuing vinyl in the first place. So to answer your question, yes, you will need a decent stereo system / phono stage to get a resonable result from your vinyl.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Audio > Phono > Starter Kit ????? [ « Previous ] [ Next » ]
