Thread: Energy ES8 replace or not? |
Bronze Member Username: Rh1
Post Number: 38 Registered: Jun-04
| Posted on Monday, June 14, 2004 - 02:23 pm: |
I have just purchased the following: Kenwood Vr5700 receiver, Wharfedale Diamond 8.3 fronts, Diamond 8 center, Diamond 8.1 surrounds. I have the Energy sub already, but I am wondering if I should buy a sub to match the speakers I have just purchased. I know that matching regular speakers is important but I am unsure on the sub. |
Post Number: 43 Registered: Jun-04
| Posted on Wednesday, June 16, 2004 - 01:34 pm: |
follow up...I have the Energy Es8 sub. Bought it 7 years ago so I figure it's probably time to replace. |
Silver Member Username: Project6
Post Number: 824 Registered: Dec-03
| Posted on Thursday, June 17, 2004 - 09:50 pm: |
check into HSU or SVS subs...very niiiice! |
Post Number: 74 Registered: Jun-04
| Posted on Friday, July 09, 2004 - 10:34 am: |
Just a quick question. I am wondering if picking up another Energy ES8 sub would be the best idea. I like the sub with my system but my question is this, would adding another sub sound louder without increasing the volume. I guess what I mean is will it appear that there is more bass since there would be two subs but not increase the overall volume. I am concerned about too much base as I live in an apartment. How would you hook up the other sub since I am using my pre-out for the one I have currently. I do have another sub pre-out located in my "dvd" box on the back of my receiver. I assume this pre-out is only activated when the dvd player is being used. Which if this is correct would be perfect since I listen to dvds and cds solely thru it. |
