Home > Message Board > Home Audio > Speakers > DIY Speaker
Author Thread: DIY Speaker
Username: Arande2
Rattle your ...
Missouri
Post Number: 2951
This is a speaker DRIVER I'm talking about.
Does anyone know of a forum or maybe a source I can go (to learn more about this)?
The reason I ask is
A) I scheduled physics next year and hope I get to do a project like this (or an amplifier maybe, or some sort of opamp-based audio circuit?)
B) This is the basic career (audio design etc) I'm hoping to follow, so practice would be cool.
I know the basics, like the factors that affect performance, such as magnet strength (and field), heat dissipation, resonance (from mass and compliance), materials (stiffness, strength, mass, etc..).. all that good stuff.
But I'd like a bit of help with more info, thanks.
Username: Jan_b_vigne
Dallas, TX
Post Number: 13484
http://www.diyaudio.com/forums/forumdisplay.php?s=c63888d9a6cd1fa45de62a53303414 32&forumid=22
http://www.t-linespeakers.org/design/classic.html
http://www.subwoofer-builder.com/
http://www.thielesmall.com/database.asp
http://www.pvconsultants.com/audio/frdgroup.htm
https://mywebspace.wisc.edu/jstalnak/web/VoightPipeSpeakers/
http://fullrangedriver.com/singledriver/links.html
http://www.highefficiencyloudspeakers.com/user/Veneering%20Loudspeaker%20Enclosu res.pdf
http://www.silcom.com/~aludwig/Loudspeaker_construction.html
http://www.the12volt.com/caraudio/boxcalcs.asp#rec
http://www.sengpielaudio.com/calculator-wavelength.htm
http://www.mcsquared.com/wavelength.htm
http://audiogrid.com/audio/
http://www.speakerbuilding.com/software/
http://www.t-linespeakers.org/linx/linx.html
http://www.madisound.com/
http://sound.westhost.com/site-map.htm
http://www.audiogearreviews.com/tech/theory/system_design/system_design.asp
http://www.psbspeakers.com/audio-topics/The-Frequencies-of-Music
http://harada-sound.com/sound/handbook/defa-d.html
http://www.symphonysound.com/articles/tubefriendly.html
http://www.audioholics.com/education/acoustics-principles/acoustics-101-course-b y-john-dahl-of-thx
Also research "Floyd Toole" and "Martin King loudspeaker CAD software" but these deal mostly with speaker systems. You will not find very much technical information on line about specific drivers or about driver design. You can look through a few driver manufacturer's web sites. Sites for Paradigm, KEF, B&W, etc. don't really tell you about their drivers so hit places that build raw drivers. Stick "DIY loudspeaker" in a search engine and start looking. Your best bet is to hook up with the DIY "Loudspeaker" site and ask if anyone there has any more suggestions. There used to be a guy over there who I think went by "Planet Ten" who should be able to help you out.
Username: Nuck
Post Number: 12022
Just kidding Andre.
Keep up the good work!
Username: Arande2
Rattle your ...
Missouri
Post Number: 2952
Thanks JV
I've been looking around on Google (and some of the links).
It's probably going to end up as 2 versions (if I get there):
A summer project
A winter project
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Audio > Speakers > DIY Speaker [ « Previous ] [ Next » ]
