Home > Message Board > Home Audio > DAC and Transports > Using TDA1541A as ADC with pc
Author Thread: Using TDA1541A as ADC with pc
Username: Nansh
Hi, i need to convert analog signal from sensors inorder to send it to pc, but i cannot find any type of ADC in my country(Ethiopia) but finally i found TDA1541A DAC. Then i planned to use pc as binary counter via parallel port to feed to the DAC, and op-amp as comparator of DAC output and signal from sensor. Using this method i may use DAC TDA1541A. So please tell what wrong if i use this method THANKYOU!
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Audio > DAC and Transports > Using TDA1541A as ADC with pc [ « Previous ] [ Next » ]
