Thread: RCA to USB cables |
New member Username: Rickwilliams
Post Number: 1 Registered: Apr-09
| Posted on Wednesday, April 01, 2009 - 11:24 pm: |
I need a solution to connecting my receiver (RCA jacks) to my computer (USB) port. I want to record my LPs to my PC and want to retain the stereo sound. Any help? Thanks. |
Post Number: 2 Registered: Apr-09
| Posted on Tuesday, April 07, 2009 - 09:35 pm: |
....or can it even be done? |
Platinum Member Username: Nuck
Post Number: 12021 Registered: Dec-04
| Posted on Wednesday, April 08, 2009 - 05:34 am: |
Rick, look up computer cards with analog inputs, they come with program and cable. Havnt tried any to recommend. |
Post Number: 3 Registered: Apr-09
| Posted on Friday, April 10, 2009 - 04:23 pm: |
Thanks Nuck. At least it's a starting point! |
Gold Member Username: Frank_abela
Berkshire
UK
Post Number: 3610 Registered: Sep-04
| Posted on Tuesday, April 14, 2009 - 09:15 am: |
Alternatively you can buy a dedicated phono stage from Project called the Phono USB. It takes the output of your record deck and digitises it for you. The phono stage (it's a gain stage purpose made for record decks) is most likely better than that in your receiver. This way you don't need the receiver in the middle. |
Post Number: 4 Registered: Apr-09
| Posted on Thursday, April 16, 2009 - 08:07 pm: |
Thanks! I think the PhonoUSB is exactly what I am looking for. I found various models from different companies. Thanks again. |
