Thread: Stands for Dynaudio 52SE? |
New member Username: Mattsa
Post Number: 1 Registered: Apr-09
| Posted on Wednesday, April 01, 2009 - 02:41 pm: |
I've just recently moved and my 52SEs (which I love) are in desperate need of some stands. My old place had a beautiful deep shelf just the right height so I never bought any, but no such luck in the new abode. I know the stand 4s are supposed to be great, but I'm not married to brand-matching and I am a little cost-sensitive as I'd rather put the extra $$ into equipment if I can help it. I'd also like to find a decent rack for my components, three shelves probably all I need. Thanks in advance for any recommendations! |
Platinum Member Username: Nuck
Post Number: 11982 Registered: Dec-04
| Posted on Wednesday, April 01, 2009 - 04:30 pm: |
Matt, have a look at the Target line. The MR24 and MR30 are good mass-loadable stands. Also see the racks. |
Gold Member Username: Dmitchell
Ottawa,
Ontario
Post Number: 2375 Registered: Feb-07
| Posted on Wednesday, April 01, 2009 - 05:49 pm: |
Hey Matt, a lot of us on here consider proper speaker stands as part of our system and "equipment" (what I mean is a good stand can make a big difference). Check out this place: http://www.skylanstands.com/stands.htm |
Post Number: 2 Registered: Apr-09
| Posted on Saturday, April 04, 2009 - 07:45 pm: |
Thanks for the suggestions guys! I definitely didn't mean to suggest I thought stands are not important, I just figure at my stage an extra $200 in my source is going to make a bigger difference than spending an extra $200 on stands. Does it matter enough that I should consider springing for the actual Dynaudio ones? |
Post Number: 12007 Registered: Dec-04
| Posted on Sunday, April 05, 2009 - 07:14 am: |
Thats up to you, Matt. But suffice to say that the Dyn's will not do what they are designed to do best without proper support. If the 52's worked well on a shelf, I have to wonder about the rear port blooming the bass somewhat, and you may want to move the speakers around a bit to get them just right. http://www.audioholics.com/reviews/speakers/bookshelf/dynaudio-52se As stated there, if you thought the Dyn's were bass heavy near a back wall, you might find a little lacking without the wall reinforcement and be tempted to crank it up a bit. |
Gold Member Username: Frank_abela
Berkshire
UK
Post Number: 3605 Registered: Sep-04
| Posted on Monday, April 13, 2009 - 11:33 am: |
Matt Personally I prefer the Partington Super Dreadnought under that speaker. That said, the Dynaudio stand is good. What you're looking for is a medium mass (i.e. reasonably heavy, usually part-sand-filled) stand, preferably welded together rather than screwed togethjer since the latter tend not to have the same strength or integrity. |
Post Number: 3 Registered: Apr-09
| Posted on Tuesday, April 21, 2009 - 01:03 am: |
Frank, Thanks for the suggestion, the dreadnoughts look great. What would you recommend for attaching the dyns to the stands? I saw one review discussing toppers (isolation cones) vs. just using bluetack, what do you think is the way to go? Thanks! |
Berkshire
UK
Post Number: 3634 Registered: Sep-04
| Posted on Tuesday, April 21, 2009 - 10:11 am: |
Blutac all the way. You need to couple the speaker to the stand to help it dump the extra energy to ground. I can't remember if the Super Dreadnought comes with sand or not. |
