Thread: Rega Brio Varieties, Please advice |
New member Username: Gbb
Post Number: 3 Registered: Mar-09
| Posted on Wednesday, April 01, 2009 - 06:20 am: |
Hi all, I'm new to the forum, having just gotten my old equipment out of storage. I'm looking to upgrade amp, speakers and tt, for a straightforward modern tt-based system. I'll probably get a project debut tt to start w, and was looking and reading about the rega brios for a nice affordable int amp. There seem to be several versions available used, and wanted to know if there are significant differences between them I should consider. There are currently 3 on ebay and ebay.uk that will go for a little under 200, yet they seem to be the early versions, as they don't have a number after the brio name. Should I hold out for the brio 3, or are the differences relatively minor? ALso, how much should a brio 3 go for used? Thanks in advance, GB |
Gold Member Username: Artk
Albany,
Oregon
Post Number: 9308 Registered: Feb-05
| Posted on Wednesday, April 01, 2009 - 07:08 am: |
The Brio 3 is the better of the bunch and would likely go for $400 or so U.S. used. |
