Thread: Integrated Amplifier for Dali Lektor 2 |
New member Username: Bhaskar
Post Number: 1 Registered: Mar-09
| Posted on Monday, March 23, 2009 - 01:42 pm: |
I need advice on what amp to pair with my Dali Lektor 2 speakers (http://dali-speakers.com/display_content.php/INT/speakers.html/189/1426) quick specs of these lektors: Sensitivity (2,83 V/1 m) [dB]: 85,0 Nominal impedance [ohms]: 6 Maximum SPL [dB]: 106 Recommended amplifier power [W]: 25 - 100 I will be using them for music and movies (40%/60%) through the RCA out from an Asus Xonar Essence PCIe card. I currently use Sennheiser cans for all music and movies and it sounds really nice, so I want something that will sound pretty decent (with movies) without burning a hole in my pocket. I plan to spend around £400 for the amp. Cheers! |
New member Username: Mike19
Tallahassee,
Fla
Post Number: 1 Registered: Jan-09
| Posted on Wednesday, April 01, 2009 - 07:56 am: |
Hi Bhaskar. I would welcome you to this Forum, but this is my first post here too. I'm not sure I understand what you want. Are you going to do stereo or multi-channel? If multi-channel, 5.1 or 7.1? Are you looking for amplification only or an audio/video reciever (processor + amplifiers)? If an avr, do you want it to be able to decode Dolby True HD and DTS Master HD? |
Platinum Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 13469 Registered: May-04
| Posted on Wednesday, April 01, 2009 - 01:26 pm: |
. If you have the opportunity, try any of the excellent Lirpa integrated amplifiers. . |
Gold Member Username: Dmitchell
Ottawa,
Ontario
Post Number: 2385 Registered: Feb-07
| Posted on Friday, April 03, 2009 - 11:09 pm: |
That seems pretty obscure Jan. What the heck is a Lirpa? |
