Thread: VT-1 to PC Cable |
New member Username: Robouser
Post Number: 1 Registered: Mar-09
| Posted on Thursday, March 05, 2009 - 08:08 pm: |
Hello everyone. I just purchased a Boss VT-1 and need to connect it to my PC MIC IN connection. It will look like this. Mic -> VT-1 -> PC I need to know which cable I need to get to connect from the VT-1 MIC OUT connection to the computer MIC IN. The connections on the VT-1 look like this:
Also, the manual for the VT-1 is located here: http://uploads.shrike.us/BossVT-1manual.pdf Also, are there any adapters that would allow a standard PC microphone (non-USB) to connect to the VT-1 INPUT connection? Thanks for the help and links are much appreciated. |
Gold Member Username: Dmitchell
Ottawa,
Ontario
Post Number: 2312 Registered: Feb-07
| Posted on Friday, March 20, 2009 - 09:51 am: |
What does this thing do? You'll more than likely need some sort of adapter to connect this to your mic on your soundcard. |
Post Number: 2 Registered: Mar-09
| Posted on Friday, March 20, 2009 - 01:44 pm: |
Thanks, I already found the adapters I needed.  |
Platinum Member Username: Nuck
Post Number: 11861 Registered: Dec-04
| Posted on Friday, March 20, 2009 - 09:18 pm: |
Another satisfied OP. Cheers MH |
