Thread: CAD-805C Mono Block |
New member Username: Ggregt01
Athens Greece
Post Number: 1 Registered: Feb-09
| Posted on Thursday, February 19, 2009 - 10:31 am: |
Hi to all. Has anyone the specs on the IS-805 interstage iron and also the CT-805 output. Thanks |
Silver Member Username: Jazzman71
Phoenix,
AZ
Post Number: 545 Registered: Dec-07
| Posted on Saturday, February 21, 2009 - 11:19 pm: |
Have you contacted Cary? |
Athens Greece
Post Number: 2 Registered: Feb-09
| Posted on Sunday, February 22, 2009 - 01:06 am: |
No I have't. Would they give that info out though? |
Silver Member Username: Soundgame
Richmond Hill Toronto,
Ontario
Post Number: 641 Registered: Jun-08
| Posted on Sunday, February 22, 2009 - 09:27 pm: |
Doesn't hurt to try and if nothing shows on Google, going to the source might be a good start. |
Phoenix,
AZ
Post Number: 554 Registered: Dec-07
| Posted on Monday, February 23, 2009 - 07:20 pm: |
Cary's customer service has been very helpful to me. If you are trying to determine if components are in spec, they might help you out. The worse that can happen is they say no. |
