Thread: Naim Nait 5i and Monitor Audio Silver RS6 |
New member Username: Kerio
Romania
Post Number: 1 Registered: Feb-09
| Posted on Thursday, February 12, 2009 - 11:08 am: |
Hello guys, I purchased last week next configuration:NAD C542BEE,NAD C325BEE and a pair of MA Silver RS6. Right now I have an offer to buy a Naim Nait 5i amplifier for arround 1000 USD. Do you think it is a semnificative improvement stepping from 325 BEE to Nait or should I keep NAD based on the rest of my system? I am afraid of how this amplifier could mate with RS6 which are known to be bright speakers. Thanks, |
Platinum Member Username: Nuck
Post Number: 11588 Registered: Dec-04
| Posted on Saturday, February 14, 2009 - 07:25 am: |
Catalin, I dont find the MA speakers to be overly bright, the RS does use a metal dome tweeter, however, which can be offensive in some room treatments. If you like the way NAD presents the music, then you wouldnt think it was the same music with Naim. The Naim is a significant step away from the NAD presentation, of course. Once you start with Naim gear, it really can be a slippery slope in spending, IMO. |
Romania
Post Number: 2 Registered: Feb-09
| Posted on Saturday, February 14, 2009 - 09:22 am: |
Thanks for your answer Nuck, Everyone seems to agree that Nait is a significant step from NAD. My only fear related to Naim is the hum reported by some people in the forum but I think I will take my chance and buy this one. |
Gold Member Username: Frank_abela
Berkshire
UK
Post Number: 3563 Registered: Sep-04
| Posted on Monday, February 16, 2009 - 01:19 pm: |
Naim amps use fairly big toroidal transformers. Any DC component in the mains supply will cause the transformer to vibrate and therefore hum to a greater or lesser degree. Hum is usually most noticeable at peak periods. There should be no hum from the speakers, that would indicate a fault. Naim amps also hiss a bit. The hiss is not present or obvious when music is playing. Although the Naim amp can accept any cables, you should seriously consider using it with Naim cable if you can. It makes a fair difference to most others. Also, do NOT biwire. Try to get some quality cablesnips between the biwire terminals of your RS6s instead, preferably the same as your speaker cable. |
Gold Member Username: Dmitchell
Ottawa,
Ontario
Post Number: 2114 Registered: Feb-07
| Posted on Monday, February 16, 2009 - 09:47 pm: |
Why is it a slippery slope Nuck? |
Gold Member Username: My_rantz
Australia
Post Number: 2036 Registered: Nov-05
| Posted on Tuesday, February 17, 2009 - 12:35 am: |
It's because Naim is so smoooooth David. LOL! |
Romania
Post Number: 3 Registered: Feb-09
| Posted on Sunday, March 15, 2009 - 10:02 am: |
Dear friends, In the end I kept the C325BEE simply because the seller changed his mind! All this time I wondered why everybody thinks NAD has a warmer presentation while my rig was "cold", with a narrow soundstage, harsh and bass shy. Only after I got my new pair of HD650 headphones, I realized that something is wrong with cable matching and not with the speakers/amplifier setup. The first thing that I did was to change the existing interconnect cable (Eagle Cable MC90 - 44USD)with an old Bandridge cable left somewhere in my house. The sound changed dramatically after cable replacement, the soundstage opened and everything was more musical than before. Along with these changes I found that was an evident loss of resolution but overall all sounded better. Now I am stuck between choosing the right cable so I narrowed my options to these cables: • QED QUNEX 3 (I heard that is good for NAD/MA combination) • Chord Crimson • Supra EFF-ISL (recommended by a friend who has same audio configuration 325BEE / MA RS6) What would be your suggestion? I must confess that I found a little bit of lack of high frequencies on NAD/RS6 with too much mid frequencies emphasis. Should I buy also a silver based speaker cable? I suspect also that my current cable is low quality too. http://www.eagle-cable.com/haupt.asp?topnavi=produkte&ser=2&lab=30&lang=en http://www.eagle-cable.com/haupt.asp?topnavi=produkte&ser=3&lab=38&lang=en |
Post Number: 11792 Registered: Dec-04
| Posted on Sunday, March 15, 2009 - 10:24 am: |
Catalin, what you are describing is what I consider to be the NAD house sound, with lots of bass. |
Romania
Post Number: 4 Registered: Feb-09
| Posted on Sunday, March 15, 2009 - 10:29 am: |
Yes Nuck, Is the sound I didn`t get with initial cables. Are you familiar with this brand (Eagle Cable)? |
Romania
Post Number: 5 Registered: Feb-09
| Posted on Sunday, March 15, 2009 - 10:32 am: |
And ,of course,any recommendations for my future cable? |
Silver Member Username: Smwick
B.C
Post Number: 214 Registered: Dec-07
| Posted on Sunday, March 15, 2009 - 02:39 pm: |
I'm really liking my new Canare 4S11 speaker cable from Bluejeanscable.com. I have the IC's as well,very nice with out paying big$$. |
Gold Member Username: Artk
Albany,
Oregon
Post Number: 9153 Registered: Feb-05
| Posted on Sunday, March 15, 2009 - 03:35 pm: |
Yeah I'm going to loom up my HT with Blue Jeans...good quality on the cheap. |
Ottawa,
Ontario
Post Number: 2276 Registered: Feb-07
| Posted on Sunday, March 15, 2009 - 03:37 pm: |
I agree Art. I have BJ's on both my 2 channel and HT sytems. |
