Thread: Arcam rDock background hum |
Bronze Member Username: Lazoroski
Skopje,
Macedonia
Macedonia, T...
Post Number: 32 Registered: Jul-06
| Posted on Sunday, January 25, 2009 - 07:34 am: |
Dear all, First my apology for posting this thread in the CD players category, but it seems that Cd players forum attracts more experienced people than the Mp3 forum. Anyway, I borrowed and Arcam rDock from a friend to try it out in my setup. It does sound good however as soon as I plug it in a get unusually high background hum on the whole system (whatever source I choose). As I unplug it the hum goes away. It sounds like an not grounded turntable. Am I'm doing something wrong or is it the dock (in which case is pretty disappointing as it costs 200 EUR) ?? Thanks and brgds, Zoran |
Gold Member Username: Stu_pitt
Irvington,
New York
Post Number: 3146 Registered: May-05
| Posted on Tuesday, January 27, 2009 - 04:34 pm: |
Did/does the problem occur when in your friend's system? Any way to try it in his or another system? The problem could be the dock itself, the power supply, or the interconnects. Try different RCAs and see what happens. If you have an identicle power supply, try that out. I assume that there's a way of figuring that out from the numbers on it, but I'm not sure. If you're unsure, don't try it. I'm not very good with grounding issues and diagnosing them, but I'd try these things first. |
Irvington,
New York
Post Number: 3147 Registered: May-05
| Posted on Tuesday, January 27, 2009 - 04:37 pm: |
Also, it may be too close to your turntable cartridge or phono stage. Try moving it further away from those if at all possible. I'm not sure if the interconnects on the rDock are captive or removable. |
Gold Member Username: Frank_abela
Berkshire
UK
Post Number: 3531 Registered: Sep-04
| Posted on Thursday, January 29, 2009 - 01:15 pm: |
Zoran, You're getting an earth loop which can be caused by any electrical items which are hooked up to each other. Ensure your rDock is plugged into the same mains or on the same mains block as the rest of your system. |
Skopje,
Macedonia
Macedonia, T...
Post Number: 33 Registered: Jul-06
| Posted on Thursday, January 29, 2009 - 05:48 pm: |
Thank you all ! I'm out of home these few days and I will try your suggestions when I get back. BRgds, Zoran |
