Thread: Sub hook up |
New member Username: Pbaker24
Post Number: 1 Registered: Jan-09
| Posted on Friday, January 23, 2009 - 12:26 am: |
I was wondering i have a Yamaha AX-596 ineragated amp,is there any way to hook up a JBL PB-10 subwofer to it.the amp has no sub hook up conection,nor any low imput hook ups on it, any info on this would be great! thanks... |
Platinum Member Username: Nuck
Post Number: 11457 Registered: Dec-04
| Posted on Friday, January 23, 2009 - 06:40 am: |
PB, you can use the high level inputs to the sub from your speaker leads. Just parallel the speaker runs from the amp and speakers, run another pair to the sub. In this manner, you can control the frequency of the subs output. |
