Thread: Interconnect Question |
Silver Member Username: Jazzman71
Phoenix,
AZ
Post Number: 491 Registered: Dec-07
| Posted on Saturday, January 17, 2009 - 02:11 am: |
On a CDP with balanced and rca analog outputs connected to an integrated amp with rca inputs, is there any advantage to using the balanced outputs with an xlr x rca cable? |
Platinum Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 13297 Registered: May-04
| Posted on Saturday, January 17, 2009 - 09:27 am: |
. Depends on the unit. Not all balanced lines are created or resolved equally. You should try botn. Most dealers will have a loaner set of cables to experiment with. . |
Phoenix,
AZ
Post Number: 499 Registered: Dec-07
| Posted on Saturday, January 17, 2009 - 11:37 pm: |
Thanks Jan, I'll give 'em a tryout. |
