Home > Message Board > Home Audio > CD Players > NAD 521bee problem
Author Thread: NAD 521bee problem
Username: Burnt0013
North Arlington, NJ
I have a 521bee and for the most part I really like it. However it can be picky about seeing discs. I often get the no disc message. Does anyone know a tweak or a solution to this problem?
Username: Edison
Glendale, CA
US
Post Number: 857
Clean the disks with brasso - if the scratch on the disks are the problem, this probably will help.
Username: Dmitchell
Ottawa, Ontario
Post Number: 2012
I've heard toothpaste works as well. At least your disks will be minty fresh.
Username: Magfan
Post Number: 415
Toothpaste contains very light polish and will work. Don't use Fluoride toothpaste.
I put a dab on my (clean) finger and rub in a circular motion. Use a soft white cloth for removal. NO paper.
Username: Nuck
Post Number: 11464
Have fun with this guys
http://forum.ecoustics.com/bbs/messages/1/216794.html
Username: Burnt0013
North Arlington, NJ
Thanks guys. Nuck it's going to take a while to sort that out.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Audio > CD Players > NAD 521bee problem [ « Previous ] [ Next » ]
