Thread: Subwoofer box? |
New member Username: Fistofgod
Post Number: 1 Registered: Nov-08
| Posted on Wednesday, November 19, 2008 - 04:47 pm: |
hey ive got an old adire audio brahma 15" mk 1...the old school ones that actually put out sound...not the new one...its freshly reconed by fi...im looking to incorporate it into my home stereo...i want this thing to play good and low...want to tune it to 20hz or so...box size is the only problem...im in a dorm room...any suggestions on size...heres a link to the t/s params...i have the 15" brahma mk 1... thanks... http://www.adireaudio.com/Files/OldAdireDrivers.pdf |
Post Number: 2 Registered: Nov-08
| Posted on Wednesday, November 19, 2008 - 04:50 pm: |
ps...ive got a crown ce1000...plan to put the 2 2ohm coils in series...the crown puts out about 1000rms at 4 ohms..should be enough power for just about any box i decide to go with...thanks! |
Platinum Member Username: Wingmanalive
A pic is worth
1000 posts!!
Post Number: 19008 Registered: Jun-06
| Posted on Wednesday, November 19, 2008 - 08:18 pm: |
1000w rms at 4ohm? Be sure not to drown out the rest of your system. In a dorm room? Be sure not to drown out your dorm. |
Post Number: 3 Registered: Nov-08
| Posted on Wednesday, November 19, 2008 - 08:29 pm: |
i made designed a pair of speakers with the help of my engineering professors...they'll keep up great...haha...ive got a crown ce1000 on them as well...300rms x 2 @ 8ohms...with a homemade crossover that i designed...bought the parts off of parts express...what a great site!  |
A pic is worth
1000 posts!!
Post Number: 19009 Registered: Jun-06
| Posted on Wednesday, November 19, 2008 - 10:00 pm: |
Yup. It's where I bought my 1000w Dayton and 500w Bash plate amps. Also good site for speaker building supplies. Recently bought a decent 100w Sherwood receiver for $100. Not bad for the $. |
