Thread: Classe CP-35 or DR5 |
Bronze Member Username: Snapcat
Post Number: 74 Registered: Oct-07
| Posted on Saturday, October 25, 2008 - 01:53 pm: |
Any thoughts on either of these with a Rotel 1080 amp in balanced set up to drive B&W (600's) or PSB (Image) bookshelf speakers? |
Platinum Member Username: Nuck
Post Number: 11025 Registered: Dec-04
| Posted on Saturday, October 25, 2008 - 04:13 pm: |
The DR5 is a very good pre, especially the phono. It has no remote. The cp35 usually has no phono, and if it does it is not very good. Has remote. The cp 35 has a FL display that has been known to cause problems(I just fixed mine), but works flawlessly regardless. The DR5 has a bias adjustment, so matching to another amp is a bit better. Both are balanced, extremely quiet and musical, with the cp35 being a touch more dry than the fuller DR5. |
Post Number: 11026 Registered: Dec-04
Both are at the minimal end of their respective series', thus the lower $. |
Post Number: 76 Registered: Oct-07
| Posted on Saturday, October 25, 2008 - 05:28 pm: |
Thanks Nuck, just what I needed. Don't need the phono. Real reasonable $ on A'gon. Looks like a great option for a balanced pre at reasonable price. |
Post Number: 11028 Registered: Dec-04
| Posted on Saturday, October 25, 2008 - 06:31 pm: |
I believe so, yes, snapcat. Mine is a cp50 from the same line, very similar. |
Gold Member Username: Nickelbut10
Post Number: 2042 Registered: Jun-07
| Posted on Sunday, October 26, 2008 - 12:01 am: |
Classe Rocks. I am going to try some of their stuff out soon. Or come to Nucks house to hear it. BOING!!! |
Gold Member Username: Dmitchell
Ottawa,
Ontario
Post Number: 1661 Registered: Feb-07
| Posted on Friday, October 31, 2008 - 11:16 pm: |
I gotta buy something new soon, so I get the "BOING!". |
