Home > Message Board > Home Audio > DAC and Transports > Super Pro USB 707 and Foobar
Author Thread: Super Pro USB 707 and Foobar
Username: I_am_kirk
Post Number: 44
I am having some troubles. I am pretty sure it's foobar related but it do love Foobar :-( I plugged in the dac, and with normal output the songs crackle and stuff a bit. I put the ASIO stuff on next and it helps with the noise and the clicking when I skip songs. Unfortunately I get a few drop outs during a song. Running a HD over ethernet from main PC to media pc then use VNC viewer to play songs. Media Monkey seemed to fix problem (but i still want to know why foobar went wrong). I used to have a creative external S/C with USB and never had a problem with dropouts (hence why i didn't point to ethernet streaming as the problem). PC doesn't overload cpu to cause it either.
Username: Dmitchell
Ottawa, Ontario
Post Number: 1634
That's really weird Kirk. I'm using the same DAC with Foobar (with the standard configuration), and it works great.
Which version of Foobar are you using?
Username: I_am_kirk
Post Number: 45
Newest one. I ended up going back to my external creative soundblaster to feed to this dac and it works great so maybe the onboard sound on my media pc (and a laptop i tested) just wasn't the best to pass to dac.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Audio > DAC and Transports > Super Pro USB 707 and Foobar [ « Previous ] [ Next » ]
