Thread: Speakers for 100-150$ each |
Gold Member Username: Terry6405
Sullivan,
IN
US
Post Number: 1014 Registered: Sep-05
| Posted on Friday, October 03, 2008 - 05:47 pm: |
I'm looking for a pair of speakers to be run by an old insignia 6ch reciever that claims 100watts a channel. I'd like them to or pa style speakers because I plan to use them as a budget sound system in my wedding soon. I've looked at the mtx ts1200 and it seems like it would to the job. Anything else I should look at? Thanks |
Gold Member Username: Dmitchell
Ottawa,
Ontario
Post Number: 1554 Registered: Feb-07
| Posted on Friday, October 03, 2008 - 06:18 pm: |
Start combing the pawn shops for some used Cerwin Vegas. Either that, or buy a set of Klipsch from a big box store for the big event, then return them. Best Buy/Future Shop offer full money back within 30 days. Not that I've ever done this before.... |
Platinum Member Username: Nuck
Post Number: 10933 Registered: Dec-04
| Posted on Friday, October 03, 2008 - 07:31 pm: |
Yes, Terry, you should be looking at renting gear for the occasion. It's cheap. |
Sullivan,
IN
US
Post Number: 1015 Registered: Sep-05
| Posted on Friday, October 03, 2008 - 10:50 pm: |
Well, anything I get I will have for my home theater,so... Any suggestions on brands? Those mtx any good? Peavey ? |
