Thread: Bose Lifestyle 20 woofer |
New member Username: Denkees
Post Number: 1 Registered: Oct-08
| Posted on Friday, October 03, 2008 - 05:23 am: |
I have bought a Bose lifestyle20 powered woofer LSM20CU102515 to use it as a woofer in a non Bose system. I don't have the cubes. I found the pin-out configuration of the 5-pin Din connector so i can connect it. Are the cubes also powered speakers or is there an amp in the woofers for the cubes ? And does anyone know how to open the unit ? |
Platinum Member Username: Nuck
Post Number: 10930 Registered: Dec-04
| Posted on Friday, October 03, 2008 - 04:05 pm: |
http://forum.ecoustics.com/bbs/messages/1/125990.html |
New member Username: Scarab28xlt
Germany
Post Number: 2 Registered: Dec-08
| Posted on Saturday, December 13, 2008 - 05:17 am: |
Hello kees van loon, can you help me im looking for the pin-out configuration of the 5-pin Din connector for my sub to connect the sub to a av-receiver. Thanks for your help. |
Post Number: 2 Registered: Oct-08
| Posted on Sunday, December 14, 2008 - 09:01 am: |
1= +12 volt don't need it 2= R- and L- 3= L+ 5= R+ kees |
Germany
Post Number: 3 Registered: Dec-08
| Posted on Sunday, December 14, 2008 - 01:34 pm: |
Thank you for your fast help. pin1 +12V is it for switch on the sub ?? Have you a picture, where i can see what are pin1 on the connector. |
New member Username: Rishan1
Post Number: 3 Registered: Aug-09
| Posted on Monday, August 17, 2009 - 08:25 pm: |
I have a Lifestyl 5 Series III and I need to connect to my Audio Receiver how do i do that? with 5pin DIN connection |
