Home > Message Board > Home Audio > Amps > Archive through July 28, 2004 > Amp Problems
Author Thread: Amp Problems
i use to have a 4ch radio but i replaced it with a 2ch radio. my amp isn't lettin my subs bump like they did with the other radio. i have a 400watt legacy amp and 2 10" jenseng subs. i got the RCA cords and a splitter but i dont know why my subs are hittin anymore. the old radio said 4x40, my new one doesn't say anythin like that. it just says that its 160 watts. can anyone help me?
Username: Project6
Post Number: 676
try the car audio forums...better advice there:-)
big kev
i have a 800 watt amp and a 50x4 panasonic cd player with 2 15 inch powerbass subs and its just not hittin as hard it shood whats the dam problem?
Username: Project6
Post Number: 942
poor placement??? Wrong box design, sonic cancellation due to poor bandpass design, lousy acoustics...it oculd be anything. Got to the car audio forums, you can probably narrow down the problem.
pacificprincess
ihave a 200 rms amp playing a 400 nominal watts sub can this cause any damages to my unit
Username: Project6
Post Number: 954
No.
Home > Message Board > Home Audio > Amps > Archive through July 28, 2004 > Amp Problems [ « Previous ] [ Next » ]
