Thread: Speaker Burn In |
Bronze Member Username: Mixster
Lake Tahoe,
NV
Post Number: 24 Registered: May-04
| Posted on Thursday, June 10, 2004 - 12:42 am: |
Hey Guys, I hear a lot of speaker burn-in. What is the proper way to burn-in some new speakers. I bought a pair of Monitor Audio Bronze B2's if that makes any difference. |
Silver Member Username: Robertinchico
Post Number: 131 Registered: Apr-04
| Posted on Thursday, June 10, 2004 - 01:25 pm: |
There is a period where the construction of the speaker, from outer phase plug, the surround, the magnet motor, etc -- get loosened up from some normal use after assembly. The devices in the crossover "warm-up" after some signal passes thru them. This is pretty much the idea of speaker burn in. Maybe even the wood cabinets settle in a bit given the humidity, temperatures etc of their new locale. Just anticipate that your speakers will need about 50 hours to fully loosen up. Did you opt out of PSB? |
Lake Tahoe,
NV
Post Number: 27 Registered: May-04
| Posted on Thursday, June 10, 2004 - 02:41 pm: |
Yea, I opted out.....I didn't have a convenient dealer nearby and really liked the sound of the B2's. Is the volume level important for burn-in??? |
Post Number: 133 Registered: Apr-04
| Posted on Thursday, June 10, 2004 - 08:55 pm: |
Well a few hours in the mix of burn in hours with some bass energy can't hurt. Don't OVER FOCUS on speaker burn in............. I think it's a good idea to have a speaker that is at least competent and not overly expensive that you can upgrade in the near future if you want to. The overly impetuous approach I took when purchasing Paradigm Titan's, which I DISLIKED, gave way to owning Paradim Focus, which is a HELL of a deal for $320. I'll get Paradigm Monitor 5's this summer, THEN start a paced search for some $2k speakers. So with your new Bronze B2, you can enjoy them, then perhaps the PSB thing will fall into place over the next couple of months. |
Lake Tahoe,
NV
Post Number: 28 Registered: May-04
| Posted on Friday, June 11, 2004 - 10:10 am: |
I don't know....I'm pretty much diggin these B2's I wanted to listen to the Monitor 5's but the shop I went to didn't have them.....they had every other Paradigm model. |
