Thread: The digital world |
Bronze Member Username: 900ss
Post Number: 12 Registered: Jun-08
| Posted on Friday, September 12, 2008 - 11:21 pm: |
I am stuck in the old analogue world with a 2 channel Bryston pre amp and amp and a dvd cd player and don't understand the need for DAC's and all that stuff. Please enlighten this old geezer. Brewster |
Gold Member Username: Dmitchell
Ottawa,
Ontario
Post Number: 1559 Registered: Feb-07
| Posted on Friday, October 03, 2008 - 08:41 pm: |
Your CD player actually has a DAC in it. It takes the 0's and 1's (bits) from your CD's and coverts it to an analogue signal your pre-amp/amp can understand. Some DACs are much, much better than others. |
Platinum Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 13049 Registered: May-04
| Posted on Saturday, October 04, 2008 - 10:26 am: |
. Brewster, you'll have to be a bit more specific about what you need to know before we can launch into an explanation of the universe. Are you happy with that you are hearing? Is this just general confusion or are you thinking of trying a new system configuration? Have you tried placing something on the order of "how CD players work" into a search engine? . |
