Home > Message Board > Home Audio > Speakers > Archive through October 27, 2008 > Newbie question about OHM and compati...
Author Thread: Newbie question about OHM and compatibility
Username: Zzzxtreme
hi i have 6 ohm speakers. and on a potential amp that im buying, there's a switch to select 8 or 4 ohm at the back.
hmmm, must I only get 6ohm amps ?
Username: Dmitchell
Ottawa, Ontario
Post Number: 1311
Should be ok.
It's alright for the speakers to be higher than an amps minimum impedance. It's not ok for the speakers to be lower.
Username: Zzzxtreme
thanks a lot !!
Username: Stu_pitt
Irvington, New York
Post Number: 2954
6 ohm speakers will not stay at 6 ohms for any realistic length of time. Some speakers list them as 6 ohms, meaning a nominal impedence. A 6 ohm speaker may go as high as 16 ohms and as low as 4 ohms. See if they have a spec that says minimum inpedence. Some companies are more honest with these specs than others.
Username: Nuck
Post Number: 10664
If you select 4 ohms, the current will be limited and you should be safe.
Username: Frank_abela
Berkshire
UK
Post Number: 3177
Correct - if you buy 6-ohm speakers, set your amp to the 4-ohm setting and you'll be fine.
Home > Message Board > Home Audio > Speakers > Archive through October 27, 2008 > Newbie question about OHM and compati... [ « Previous ] [ Next » ]
