Thread: Pre-amps vs. power amps? |
New member Username: Joshmosh20
Post Number: 1 Registered: Aug-08
| Posted on Wednesday, August 13, 2008 - 08:05 pm: |
Can anyone tell me the difference between the preamps and the power amps? |
Platinum Member Username: Nuck
Post Number: 10645 Registered: Dec-04
| Posted on Wednesday, August 13, 2008 - 08:18 pm: |
Josh, the preamp, in whatever configuration, sends a signal to a power amp(s). the power amp does just that, amplifies the signal that it is given, into 'X' amount of output to the speakers. The preamp does all the switching, and in some cases, the decoding of signals(a processor), although these lines are somewhat blurry at the moment with various inputs and so on. A Power amp has low level inputs, and produces high power outputs at the speaker terminals. Sysyems like this are termed as 'seperates', as compare to Integrated Amplifiers, which combine the two componants. |
Platinum Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 12924 Registered: May-04
| Posted on Wednesday, August 13, 2008 - 09:28 pm: |
. Place "audio glossary" into a search engine and read the various descriptions. |
Post Number: 10656 Registered: Dec-04
| Posted on Thursday, August 14, 2008 - 11:08 pm: |
Or listen to nuck..nawwww |
Dallas,
TX
Post Number: 12925 Registered: May-04
| Posted on Friday, August 15, 2008 - 09:33 am: |
. He can listen to both suggestions. A glossary will answer a lot more potential quaestions. |
Bronze Member Username: Soundgame
Richmond Hill,
Ontario
Post Number: 16 Registered: Jun-08
| Posted on Friday, August 15, 2008 - 09:41 am: |
It does get even more complicated when you bring in processors i.e. pre/pro. I would suggest starting with the glossary and going from there. You should read about integrated amplifiers as well. All the best. |
Post Number: 2 Registered: Aug-08
| Posted on Friday, August 15, 2008 - 11:48 am: |
Thanks so much for all of your input. It has been very helpful. |
