Home > Message Board > Home Audio > Receivers > Archive through September 07, 2008 > Looking for receiver with good FM rec...
Author Thread: Looking for receiver with good FM reception in a rural area
Username: Freeheeler
CO
I'm looking to spend under $300 for a receiver that will give good FM reception in my rural, mountainous area, where the nearest radio stations are 7 and 20 miles away. (Neither my Onkyo SR603 nor my Philips MCD708 are able to pick up any stations, and my landlord won't let me install an antenna on the house.) This receiver will be used only to play music in two rooms with in-ceiling speakers (the bedroom and attached bathroom). Since I can't picture wanting to output different sources to these rooms simultaneously, a second zone isn't necessary; I can simply turn the B speakers on & off as necessary. What brands and/or models will offer excellent FM reception in a rural area? Thanks in advance for your advice!
Username: Jan_b_vigne
Dallas, TX
Post Number: 12868
http://forum.ecoustics.com/bbs/messages/1/348260.html
CO
Thanks for the link, Jan. Does anyone have a suggestion for a receiver with an integrated amp? This is going in a small space; a micro-sized amp/receiver would actually fit better, although I can make a full-sized amp/receiver work.
Thanks for your time, Ross
Username: Afj
Gaborone
Botswana
Post Number: 97
what speakers are you going to use it with ross and whats your budget
Home > Message Board > Home Audio > Receivers > Archive through September 07, 2008 > Looking for receiver with good FM rec... [ « Previous ] [ Next » ]
