Thread: More Sacrilege |
Bronze Member Username: Snapcat
Post Number: 66 Registered: Oct-07
| Posted on Saturday, July 19, 2008 - 12:16 pm: |
I recently got a Bryston BP-25 to potentially replace the NAD C372 I have been using as a preamp. Long story short. With my mixed bag of RCA connections, the NAD sounds more lively at low volume, but much harsher at high volume. The BP25 has a larger soundstage. With the Balanced connections, computer/usb/PS Audio DLIII combo the whole setup is transformed (yes, it costs much more). Wide, open soundstage, not harsh at high volume, detailed bass seems to come from everywhere not just thrust at you. I don't really know what else to say. I think I'm there for my budget. Mostly.... I do plan to get a dedicated fanless pc instead of moving the laptop back and forth. |
Platinum Member Username: Nuck
Post Number: 10557 Registered: Dec-04
| Posted on Saturday, July 19, 2008 - 12:38 pm: |
It is amaxing the hoops that we sometimes jump through to gain the benefits of fully balanced circuits. Consider that the cheapest of pro parts are always balanced! |
Post Number: 68 Registered: Oct-07
| Posted on Saturday, July 19, 2008 - 01:40 pm: |
Yep, it's louder & cleaner w/ less noise. Not sure why all products above a certain point aren't balanced. Example with integrated amps: the Mac 6900, Krell kav 400, Classe CAP 151, and NAD M3 all have balanced input. The Mac 6500 and MF A5 don't. Why not? |
Platinum Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 12831 Registered: May-04
| Posted on Saturday, July 19, 2008 - 01:44 pm: |
. Because true complimentary circuits double the cost of manufacturing. |
Post Number: 69 Registered: Oct-07
| Posted on Saturday, July 19, 2008 - 02:07 pm: |
reasonable cost reasonable time to market (schedule) technical excellence pick 2. you can't have it all. I should have seen that. |
Post Number: 70 Registered: Oct-07
| Posted on Saturday, July 19, 2008 - 02:20 pm: |
Before I offend any A5 or 6500 owners... tech excellence isn't really it. how about advanced features? or options |
Post Number: 10559 Registered: Dec-04
| Posted on Saturday, July 19, 2008 - 04:41 pm: |
Every Classe componant has always been transformer based balanced capable. If the balance is achieved through shared power supplies or refrences to neutral, then it is a 'semi' or partial connection. Actual balnced connections are not hard to achieve, as Behringer can attest to, but more expensive brands that offer these interfaces consider them to capable of demanding a premium, for whatever reason. I think it is pretty simple to offer a secondary power supply and reference to support a balanced circuitry, but then again, I support a permanent pinout selection so as to protect these circuits. If you do not own a meter, the center hot can bite you in the Levi's... |
Dallas,
TX
Post Number: 12833 Registered: May-04
| Posted on Saturday, July 19, 2008 - 05:22 pm: |
. "If you do not own a meter, the center hot can bite you in the Levi's... " The lesson to be learned is don't stick your hands where you aren't certain they belong. |
Post Number: 10565 Registered: Dec-04
| Posted on Sunday, July 20, 2008 - 08:34 am: |
The usual good advice. |
Post Number: 10833 Registered: Dec-04
| Posted on Saturday, September 13, 2008 - 11:15 am: |
Opened up the pre today to look at the wonky display. Reseat and clean edge connector(use a pencil eraser for this task), spray and reseat connections. Loosen and reseat any ic's that are on a service mount. Voila, no meter needed, all is normal again. Opened the ca300 amp while I had the stuff out, a little air(with a ground strap) and reseat everything. Scuff up the fuses and holders with scotch brite and put it back into service. |
Gold Member Username: Nickelbut10
Post Number: 1914 Registered: Jun-07
| Posted on Monday, September 15, 2008 - 10:12 am: |
Sweet Nuck. Good stuff. |
Dallas,
TX
Post Number: 13015 Registered: May-04
| Posted on Monday, September 15, 2008 - 12:49 pm: |
. "Scuff up the fuses and holders with scotch brite and put it back into service." Why scuff the fuses? . |
Post Number: 10857 Registered: Dec-04
| Posted on Monday, September 15, 2008 - 08:47 pm: |
To promote better contact in the holder. New fuses (and batteries) often have a coating of oxidant inhibitor on them, which I find is best removed. |
