Home > Message Board > Home Audio > Receivers > Archive through September 07, 2008 > Kind of a newb question
Author Thread: Kind of a newb question
Username: Dspang
But I'm having trouble choosing. I'm on a 150 to 200 dollar budget. I would like to get a surround receiver that I would configure for 2.1 setup due to the fact the room is very small. What would be a good choice?
Username: Jan_b_vigne
Dallas, TX
Post Number: 12801
Anything in that price range is a throw away item when it breaks so buy whatever sounds the best to you.
Username: Petergalbraith
Post Number: 2182
http://www.harmanaudio.com/search_browse/product_detail.asp?urlMaterialNumber=AV R%20146-Z
Username: Dspang
Thanks guys.
Username: Frank_abela
Berkshire
UK
Post Number: 3063
Darrel
Why not just get yourself a stereo amp?
Username: Dspang
That is certainly not out of the question. Any suggestions?
Username: Dmitchell
Ottawa, Ontario
Post Number: 1164
http://www.6moons.com/audioreviews/trends/ta10.html
I've owned one before. With a small room and sensitive speakers they sound really good.
Username: Dspang
Thank you for the replies fellas. I have me an HK 3480 I bought off of Harman audio. Wonderful beast of a stereo receiver. My speakers are crap though. I need to upgrade them. Any suggestions. Would you prefer I go to the speaker forums for that question?
Username: Nuck
Post Number: 10591
Darrel, have a look throught the recent posts in speakers, you will find what you need.
Or ask after looking through the posts.
Home > Message Board > Home Audio > Receivers > Archive through September 07, 2008 > Kind of a newb question [ « Previous ] [ Next » ]
