Home > Message Board > Home Audio > Speakers > Archive through July 21, 2008 > Subtle speaker noise when playing
Author Thread: Subtle speaker noise when playing
Username: Narke
Post Number: 25
Hi,
These days, I noticed that when my speakers in playing and with my ears put every close to the speaker driver (about 5 inch), I can hear some kind of backgroud noise. When I stopped or paused the cd player, the noise disapeared. For some CD discs, the noise is a little obvious and for other CD discs, it is more less.
So my question is, where the noise come from? Is that normal?
My speaker is B&W CM-1.
Thank you very much.
Username: Jan_b_vigne
Dallas, TX
Post Number: 12771
It's circuit noise made more obvious by your speakers. Unless you change components out, what you are hearing is, in all likelyhood, normal.
Username: Narke
Post Number: 26
Did you means, it doesn't indicates any problem with my speaker, is it? Thanks.
Dallas, TX
Post Number: 12773
What you are hearing is probably as normal as the set up will be. All electronic components make some amount of noise. Certain speakers make that noise more or less obvious.
Home > Message Board > Home Audio > Speakers > Archive through July 21, 2008 > Subtle speaker noise when playing [ « Previous ] [ Next » ]
