Home > Message Board > Home Audio > Receivers > Archive through September 07, 2008 > Harmon Kardon Audio Issue
Author Thread: Harmon Kardon Audio Issue
Username: Topdrop18
I recently hooked up my hd cable box to my new harmon kardon receiver. I have the audio and video going through component connections into the receiver and then out to the tv. Now the only way that I can have audio with the tv is to have the receiver turned on. Is there any way for me to have the audio work without having my receiver turned on?
Username: Afj
Gaborone
Botswana
Post Number: 83
if youre hd cable box has an rf out (and your tv has the same) you could try that
Home > Message Board > Home Audio > Receivers > Archive through September 07, 2008 > Harmon Kardon Audio Issue [ « Previous ] [ Next » ]
