Home > Message Board > Home Audio > Receivers > Archive through September 07, 2008 > Temporary Hum (through speakers) from...
Author Thread: Temporary Hum (through speakers) from receiver
Username: Gregpelletier
I get a hum in my speakers on my Harman Kardon AVR110 when I first turn it on. It is a very annoying hum. It goes away after about 30-40 mins. If I turn it off and back on, the hum returns.
Does anybody have any ideas to resolve this issue?
Username: Jan_b_vigne
Dallas, TX
Post Number: 12723
Is the unit in warranty?
No unfortunately it is not.
Dallas, TX
Post Number: 12724
Hum noises which slowly disappear as the unit warms are typically the result of defective power supply or possibly coupling capacitors. Hum in both channels suggests a power supply problem. Hum in only one channel would normally result from a coupling cap in that channel's circuitry. Take the unit to a repair shop and ask for an estimate of cost before you decide what to do.
Home > Message Board > Home Audio > Receivers > Archive through September 07, 2008 > Temporary Hum (through speakers) from... [ « Previous ] [ Next » ]
