Thread: Turntable belt size? |
New member Username: Guitaristbryan
Post Number: 1 Registered: Jun-08
| Posted on Sunday, June 01, 2008 - 06:14 am: |
hey everyone, how do i find out what size of belt i need for my turntable? i've heard of a method involving a string, but how exactly to i tell how long i need? i have a technics sl-b202. thanks! |
Relevant Product Info
Gold Member Username: Artk
Albany,
Oregon
Post Number: 6974 Registered: Feb-05
| Posted on Sunday, June 01, 2008 - 09:55 am: |
http://www.turntableneedles.com/index.asp?PageAction=VIEWCATS&Category=18849 http://www.turntableneedles.com/index.asp?PageAction=VIEWCATS&Category=20699 |
Platinum Member Username: Nuck
Post Number: 10315 Registered: Dec-04
| Posted on Sunday, June 01, 2008 - 04:02 pm: |
Bryan, you can use the string if you wish. You must know the diameter of the pulleys, the thickness of the belt, the pitch of the belt, the precise centre to centre distance between the pulley center...and a slide rule. Or use Art's links. |
Gold Member Username: Frank_abela
Berkshire
UK
Post Number: 2981 Registered: Sep-04
| Posted on Monday, June 02, 2008 - 11:50 am: |
Slide rule ... Nuck, you're showing your age. And to really twist the knife, Bryan will respond wondering what a slide rule is. |
Post Number: 10320 Registered: Dec-04
| Posted on Monday, June 02, 2008 - 02:36 pm: |
Aww heck, what's a forum if not lacking in division, anyhow? |
